Question about Goldstar R1203 Air Conditioner
Getting a/c out of window?
Looking for info and help. We want to take our Goldstar r1200 a/c out of the window. It is in an external casing that we believe is screwed into the window from from the inside of the casing. Unfortunatly, we can't figure out how to pull the a/c from the casing. When we grab on to the unit there doesn't seem to be anyway to know if we are pulling on casing or a/c - but either way nothing coming out and the whole thing torques our very very old wood frame window. Thoughts? Solutions?
Fix It was a waste of time!!!
After recieving four emails from Fix it, purporting to have collected solutions offered by "experts" -- each turning out to be solicitations for paid services and memberships but offering no solutions to our problem -- we decided to tell everyone we know that Fix It is not worth trying.
Fix It is either an outright fraud or should police the profiles and accounts on their site.
REMOVE MY MEMBERSHIP.
Posted on Jun 21, 2008
Hook up external harddrive
Need more info. Is it a USB connected external drive? Is it a newer laptop(windows 7). If both of these are yes, just plug the external drive into your laptop and windows should detect it and allow you to format for use if necissary. Also, if you purchased it, it may have come with a disk. If this is the case, don't hook anything up, put the disk in, and follow the insturctions. Hope this helped.
Sep 26, 2012 | Computers & Internet
Does goldstar still make parts for the GoldStar R5000 particularly the fans
It depends on which parts you're looking for. Some are interchangeable from other Goldstar units.
Here is a link to where you can probably find what you need..
http://www.appliancefactoryparts.com/airconditioners/goldstar/
Hope this helps you & thanks for choosing FixYa.
Aug 19, 2011 | Goldstar Heating & Cooling
Dont have the intalation disc
Here is the info from Sony's Website.
Drivers for External Optical Models Operating System: Windows Date: 04/18/2008 Do you need a Driver? (External models)
All Sony Optical external units are plug & play with Windows, no drivers are required for detection.
If you are having issues getting your external drive detected in Windows, please try the following:
The drive needs to be connected directly to USB 2.0 or I-link port (depending on model type) on your computer. Please note that the drive is not supported if connected to a dock or a hub.
Also please check the following if you are have trouble detecting:
  • The drive needs to be the only external device connected to the system. Please ensure there are no other USB devices connected.
  • Try a different USB port on your computer.
  • Try a different USB cable
  • Try the drive on a second computer system if possible.
  • Ensure you have the latest BIOS and Motherboard updates from your PC manufacturer.
  • Ensure you have the latest Windows updates from Microsoft.
I hope that this helps in some way. Please let me know if you need more help after these steps and I will try looking eleswhere. asnowman
Nov 07, 2009 | Sony DRX-820U Burner
Have 5000BTU Goldstar window unit. Water dripping
the bottom of the case from the outside usually has a "divot" in it below the coil to allow flow from the hose that runs across the bottom of the unit, try pressuring up and "blowing out" any obstruction, if this does not work then you may have to disassemble the unit and verify the drainpan is not cracked below the indoor coil (rare)
Jul 13, 2009 | Goldstar WG5000 Air Conditioner
Looking for new door for microwave
go to www.applianceart.com and purchase their vinyl option in white to cover your microwave door and get the look you want without having to go through the hassle of replacing the door.
Mar 05, 2009 | Goldstar MV-1526 Microwave Oven
Don`t cook
try opening the case and checking the internal fuses. these normally cause the problem
Feb 01, 2009 | Goldstar Over-the-Range Microwave
Microwave oven does not work
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
You can get warranty info & find a local authorized servicer.
Jan 15, 2009 | Goldstar MV-1615 Microwave Oven
Looking for a glass turntable plate model #MQS1236H
That is part # A06014000AP and you can get it here or here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 24, 2008 | Goldstar MV-1526 Microwave Oven
Goldstar MV1501
In most cases this is a bad door switch or a broken or loose door switch mount.
This is very economical for the average do-it-yourselfer as opposed to a service call, which may cost $75 to get someone in the door then another $50 or so to fix it, plus parts.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 09, 2007 | Goldstar MV-1501 Microwave Oven
Goldstar R1203 Air Conditioner Logo
79 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
