Question about PNY 2GB microSD Memory Card
Unable to read card
I formatted the 8gb SD HC card through my casio camera. I have not been able to view any pictures from the card. When I place the card in printer slot, it says "memory card error".
What do I need to do to make this card work?
You act white go to the store and raise **** and say you sold me junk
Posted on Nov 03, 2008
Reading imposible and unable to read the card SD D was (bleep) compromise
If you think there should be important pictures on the card, please don't do a thing till you recovered them.
For that use an external card reader on your computer. If there are no pictures on the card, please try to format it in the camera.
Also, if it won't work in the camera, first try to format it (FAT32) on your computer and then again format it in the camera. Also check you did not switch the card to the lock position.
Mar 05, 2014 | Panasonic Lumix DMC-ZS30 Digital Camera...
Computer Cannot read my SD Card
STOP SD MEMORY CARDS ARE NOT ALL THE SAME !This is a very common issue as of late because of the fairly recent addition to the market place with the "HC" and "XD" Cards. I have found most computer older than 2008 wont read HC and XD cards however I'm sure there are USB card readers that can fill this gap available at your local pc shop. Please look Carefully at these different formats Standard SD: 1 MB to 4 GB readable by almost all computers most often up to 2GB rarely up to 4GB 6468175.jpg
SDHC: 4 GB to 32 GB Most older Computers Cannot read the the HC format, good however for NEWER devices such as camera's, video cameras and recent phones (my cannon powershot S80 will NOT read HC format, nor will my 2007 laptop.)
SDXC: 32 GB to 2 TiB same limitations as above, Great cards for Digital Video Camera though!
here is a wikipedia note "Changes to the interface of the established format have made some older devices designed for standard SD cards (≤4 GB) unable to handle newer formats such as SDHC (≥4 GB). All SD cards have the same physical shape, which causes confusion for many consumers"
So.. in closing MAKE SURE your device supports HC and or XC before your purchase one! Also be aware that most of these cards have a lock switch on them to write protect the data, located on the side of the card. It MUST be in the Unlocked position to operate normally. Hope this helps someone out there. please use the thumbs up if it clears up anything for you! Gurvy
on Aug 31, 2010 | Computers & Internet
My canon optura 50 wont format my Toshiba 8gb SD/HC memory card
You need to check the manual to see if your camera can use SDHC cards.If your camera is older than 4 years, (I'm not familiar with your particular model), chances are it can only use SD cards.
Jan 09, 2011 | Cameras
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Unable to format kodak 8gb sd hc card on either CX7430
This particular camera only allows SD cards up to 2gb. SDHC or otherwise cards with 4gb or up will not be recognized.
As far as your computer being unable to format it, make sure your card reader is capable of operating with 8gb cards. Sometimes older card readers require firmware upgrade from their manufacturer. Please make sure your card reader is capable of operating/formatting other 8gb cards, to discard yours as faulty.
Sep 22, 2009 | Kodak EasyShare CX7430 Digital Camera
8gb sandisk micro sd hc for samsung pixon not recognised by phone
i have come to the conclusion the mgb card itself is corrupted
i put in my nokia 5800 and it says card corrupted
i format card all looks ok
remove from nokia
and put back in again
and card corrupted again,
also 8gb card from my nokia (not the same one)
works in the pixion ok
so im sending back the card
Apr 12, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Sd card issue
According to the manufacturer specs, only the mmc and sd flash protocols are supported. The sd hc protocol is not supported. There are some 4 gb sd cards that were produced before the sd hc format was produced (starting at a 4 gb capacity). Try a few different manufacturers for the 4 gb sd card.
Mar 19, 2009 | Casio Cameras
Camera Memory Card Capacity
Hi there, and welcome to FixYa.
First, make sure your cards are either, SD or MMC. Any other type won't work.
If they are SD and/or MMC cards, then the reason the cards aren't working is because they have to be formatted in the camera BEFORE you use them. Use the camera to format the cards, don't use your pc or a card reader.
The manufacturer says to use a 2gb card, but that doesn't mean you can't try a higher one. The only thing is that maybe it won't format the card right. Or, it may slow down the processing speed. It won't hurt the camera any.
Have fun with your camera. If you have any further questions, leave me a comment, and don't forget to rate my solution.
Mar 02, 2009 | Casio Exilim EX-Z750 Digital Camera
PNY 2GB microSD Memory Card Logo
192 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
