Question about Kitchen Ranges
Whirlpool Gas range will not ignite, I have replaced the spark module but I have a very weak spark. Any ideas.
    Genius:
  • 1,036 Answers
Hi there.
Check all spark points are working correctly. As you say, new spark module, so there must be a breakdown of insulation somewhere. Check to see where it may be arcing across. Usually at a trapped wire or hot contact point.
Posted on Jun 20, 2008
Oven and broiler won't light
You may need to replace the part called the igniter module. It is what creates the spark that fires the gas.
Jun 01, 2016 | Whirlpool Accubake SF362LXTS Kitchen Range
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Top burner igniters
The spark module was damaged when you lost power and will need to be replaced. Here is that part to order.
Whirlpool W10331686 Spark Module AppliancePartsPros com
There is also a video on that same page to show you how to make the repair.
Mar 03, 2014 | Amana 30 In. White Freestanding Gas range...
All igniters won't lite. very weak spark
The part called the SPARK MODULE is what produces the spark for the surface burners and it is what i would highly suspect as being the problem. Typically the spark module is located on the back behind the rear panel.
GENE
Sep 23, 2011 | Whirlpool SF357 Gas Kitchen Range
My oven's bake will not come on. You can hear the gas come on, but it will not ignite. My range and broil are working. Had it serviced, but after replacing the ignitor, gas valve and module, it...
The holes on the actual bake burner bar(tube) could be clogged so ya hear the gas coming out the rest of it, the spark cant ignite the gas since the gas isn't getting to the spark. If it hasn't been done the holes could be poked with a paper clip to assure their clear,or the burner bar could be replaced. If that doesn't fix it it's what my airplane mechanic friend would call a hanger queen and that plane will never fly.
Good luck,i hope this helps,
Gene
Aug 04, 2011 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool Gas Range Oven will not start (gas flows, but no spark)
The ignitor does 2 things. It creates the spark for ignition and it signals the control the burner is lit(flame sensor). If the ignitor and wire are new the spark module is bad. If all spark components have been replaced then I would be searching for a poor ground wire. Are you by any chance using a GFCI circuit? Not recommended and if it worked on this type of circuit you were just plain lucky.
Eric
Oct 31, 2009 | Kitchen Ranges
Whirlpool 465. The top range burners will not ignite. I can hear and smell the gas. The oven burner works fine. Do I need to replace an ignitor for the range?
The bake is seperate from the burner ignition system. You may need a new spark module for the top burners. All burners should spark at the same time even if you are only trying to lite one burner.
Aug 27, 2009 | Ovens
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
230 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
