Question about Fujitsu AMILO Pro V1000 Notebook
Memory slots have a Fujitsu Siemens Amilo L7310GW and was wondering where both of the memory slots are as I would like to upgrade the system to 1gb. Do I have to remove the key board?
  • liamgnoble Jun 30, 2008
    Thank you very much.
    Brigadier General:
  • 3,614 Answers
Switch your notebook off.
► Close the LCD screen so that it locks into place.
► Unplug the mains plug of the mains adapter from the mains socket.
► Disconnect all cables connected to the notebook.
► Turn your notebook over and place it on a stable, sturdy, flat surface. If necessary, lay an
anti-slip cloth on this surface to prevent the notebook from being scratched.
► Remove the battery
if you need manual click HERE...
Posted on Jun 20, 2008
  • micromaster
    micromaster Jun 30, 2008
    kindly please rate my solution, will yah...?
    thanks ,
    micro
Where is the 2nd memory slot in a Fujitsu-Siemens Amilo Li2727
It is adjacent to the first. Turn the laptop over, there should be a removeable cover about 2 inches square, remove the screws and carefully lift the lid. The memory will be there.
That system will support two 1GB sticks. http://www.ec.kingston.com/ecom/configurator_new/partsinfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KFJ-FPC218/1G
Hope this helps. I would appreciate your feed back.
Oct 01, 2011 | Computers & Internet
HOW MUCH RAM WILL IT SUPPORT
This model has two memory slots, it has 512 MB in one of the slot. The maximal memory to support is 1GB for each slot and 2 GB total.
CompQ
May 11, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
How to change and upgrade the memory Fujitsu-Siemens Amilo Pro Fujitsu-Siemens Amilo Pro V2010
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
Nov 18, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Can i replace 1 Gb memory (for fujitsu amilo mini
your amilo 3520 can support up to 4gig memmory that would be 2x2gig
Oct 19, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
How to upgrade ram
This computer will support up to 1Gb of RAM, it has no other expansion slots so what you have is all you have. you can go here,
http://www.memoryx.net/fpcem165.html
or go to walmart, i believe you can purchase 1G cards there with the correct spex for your comp...
Aug 11, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu-Siemens Amilo Pro V2040 Laptop memory locations?
Sorry, This laptop only supports one memory card slot upto 1.7GB
Mar 15, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Memory modules
i don't know this model (amilo pro v2040 ), but usualy the memory modules are one under the other (so u should remove the first memory module to be able to insert the one underneth it) or one facing the other (and there should be no problem in inserting the modules...) If u don't succed, you should be able to find the tehnical book of the laptop on it;s producer site ....
Jan 16, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Ram upgradation
Best to do is to know how much RAM does that computer able to take. In absence of the manuals you needed a technician to help you check it for its capabilities and then he /she can advise.
Otherwise most, laptops have 3 memory slots unlike desktops which most of them have 4 memory slots.
You need an IT man to help find where the slots are.
Dec 31, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Upgrading memory
I have found a link for you from where you can download the mannual for the notebook you are using. This mannual explains that how you can replace the memory of the notebook.
Open link
http://www.fujitsu-siemens.com/support/manuals.html
Under "Select Product" - Select Notebook - Amillo Pro - Amillo Pro V2xxx - Amillo Prov 2000
Download and open
Basic informations on mainboard Technical Mannual
You will find the details in that.
I hope that this resolves your issue.
Sammy
Nov 28, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu AMILO Pro V1000 Notebook Logo
196 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
