Question about Canon imageRUNNER 400S Copier
Paper fold may canon ir400s. main problem paper fold in Z sape.(example I I I) when use paper try but bypass use paper not fold. please help me
    Sniper:
  • 54 Answers
Change the all feeders if its not corrected replace the clutch(cl 3) in the paper deck
Posted on Aug 14, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
When you use the by-pass it's ok. when using tray paper z folds.
1- change feed & sep tires ( timing off)
2- bad seperation, roller or seperation assembly is bad or needs adjustments ( adjust in service mode or change)
Posted on Jun 20, 2008
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me....
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
Jan 06, 2011 | Canon imageRUNNER 400S Copier
After several copies the paper gets very warm and paper rolls on the edge and jams
Rolls on the edge meaning it curls upward or folds a corner? You might try pullig out the paper cassette (tray), removing the entire contents and flip upside down (face down) this should help to alievate paper curl. If it is folding corners, you may need to have serviced. Let me know, please.
Oct 09, 2009 | Canon PC-1080F Plain Paper Laser Fax
Problem during printing back to back
check the bypass if bypass not working (not pass paper) that means there are (inside) a sensor spring are loosed
May 13, 2009 | Canon imageRUNNER 3300i Printer
E677 Error in canon IR400
switch main power off and on E677
Feb 24, 2009 | Canon imageRUNNER 400S Copier
Canon IR400 copier
dear sir, I have ir400 copier. please help me to solve the error no. e051. thanks,
regards
Jan 10, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Ir400 CANON Photocopier
There is a glitch in the programm, try re-installing driver or updating it
Nov 16, 2008 | Office Equipment & Supplies
Grey Band/lines across page
your problem could be one of many things first try stoping the copy half way in the machine. to do this open the front door and cheat the door switch with some folded up paper or use a flat screw driver to bypass the switch. make a copy and watch the paper when in goes into the drum and starts to come out like 3 inches pull the screw driver or paper out of the switch. carefully pull the paper out from the machine and see if the image is ok. if the marks are there the problem is with the drum. if the image is clear and there is no marks then open the left door on the copier and inspect the rollers in the heat unit. to do this open the left door the front door has to be open to do this. there is a little green lever on the right side pull this down and look at the 2 roller if you see marks on the top roller or dirt on the lower roller this is your problem. also check the miliage reading on the drum if there is a sticker and check the meter on the machine the drum is rated for 55,000 copies.
Jan 03, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
167 people viewed this question
old marine
old marine
