Question about Linksys Wireless-G WRTP54G Router
Help what do i have to download, u said go an download what do i download. and i been on my router page. where u type admin and admin for both password and user name. but i never found anything about firmware.
  • Dirty Haxor Jun 21, 2008
    ok right now im on my laptop which is not connected to the modem, so im going to use the computer that is to dowload the firmware. should i download the latest or should i downgrade my firmware. i went on this site and they said to downgrade it. but i dont know you are the expert u tell me. ty for your time you are giving me.
  • 611 Answers
Http://www-in.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=IN%2FLayout&cid=1175234114626&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1462626605H29&displaypage=download
this the link which i am send to you in that select your product model in that select the download frimware latested version and download it .
second thing after download the firmware of the your product then you go to the router page for that you have to go the internet explorer in that address bar type 192.168.1.1 is the default ip address is there after then you get the page in that they asking username and password then you have to give username blank and password is admin. after then you go the option administrator in that option is there upload then give the path and then upload it.
Posted on Jun 21, 2008
I need to set a password for my Linksys Wireless-G WRT54G Router, but the websited 192.168.0.1 to set the password isnt working. I need help ASAP. Thank-You
to access the router page for linksys, you need to type 192.168.1.1 on the address bar. username is " admin " password is " password " if it doesnt work, try "admin" for username and "admin" for password. then it would take you to the router page. and you can start configuring.
Sep 09, 2011 | Linksys Wireless-G WRT54G Router
How do i down load set up soft ware for this router
all you need to do is:
1. disconnect your wireless antenna on your PC
2. plug your pc into the router with an ethernet cable.
3. open your browser and type in 192.168.0.1
4. the password is admin and there shouldnt be a username but if there is the default is also admin
5. configure your settings
*before you change your settings practice on this emulator in order to familiarize yourself http://support.dlink.com/emulators/wbr2310/index.htm
hope this helped plz rate thx
Mar 27, 2011 | D-Link Computers & Internet
How do I log into my router config if I don't know the password? I've tried pushing the button on the back to reset but that didn't work
Hi vmontour,
To Factory reset your router you need to locate the Reset Button at the back of the router. The Reset Button is the small hole at the back and you need a Pen or a Paperclip to press it. Press and hold the reset button for 15-30 seconds. Make sure that the router is on when you reset it.
To access the router page just open a browser then type 192.168.0.1. the username is admin and the password is blank.
Rate me if this will help you so that i can help other people.
Thanks for using Fixya.
Jan 31, 2011 | D-Link AirPlus DI-524 Wireless Router
Cant set the router to Nat open how do i do this?
Login to Zyxel Router Admin page using admin url. Refer user manual for login username, password and admin url. Type in the browser with the admin url and login. It opens to a router management page. In that click on the WAN tab and select the Enable Nat option. Thus you can open nat on your router
Oct 05, 2010 | Zyxel P660HW-D1 Router
I can't access my routers administration page. It tells me to type in http://192.168.0.1 and all I get is a bunch of search results instead of the administration page
disconnect your modem from router, or turn off your modem from router...
Now try to open...
because the router admin page will be built inside the router itself... so you never require internet connection to be ON for opening the router admin page...
Aug 02, 2010 | Computers & Internet
Linksys Router:I type in for User ID: admin and Password: admin.
Are you doing it on the laptop.
If you are doing it on a wireless computer ( even if it is connected with the cable ), disable the wireless network connection.
So that it will not use the wireless network and it will be conncted only with the wired connection.
If you are facing the same problem again and again then I believe you will need to reset the router and reconfigure the router. But if you reset the router , you will loose all the settings of the router and you will need to reconfigure the router.
If your computer is able to go on line with the wired connection then I will suggest you to upgrade the firmware of the router.
Download the firmware of the router and upgrade the firmware.
Click Here for more information about the routers and network
Apr 22, 2010 | EnGenius EOC-5610 802.11a/b/g Wireless...
Router setup page is missing items
you can find reset button in back side of router press it for 10 seconds so all settings of your router are defaults.
Then you can access your router with following link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then configure router as dhcp enabled.
also enabled wi fi
make sure you connect your router with ethernet cable to computer after resetting
Jul 15, 2009 | Linksys Wireless-G WRT54GL Router
Problem entering router password
Try going in though its IP address to setup. In internet explorer, type in (with nothing else - NO http - NO www) just type: 192.168.1.1 - then use
username - type admin
password - type admin
That should get you in without using the cd software.
Jul 03, 2008 | Linksys Wireless-G Broadband Router
Linksys wireless-G 2.4 GHz broadband Router
What is the model No. of the router ?
You can open the setup page by typing 192.168.1.1 in the address bar of Internet Explorer / Firefox.
The default password for linksys routers is admin.
Once in the setup page, click on wireless and click wireless security. There you'll find the wireless security keys.
Hope that helps :)
For information on wireless security, click here.
For the updated list of firmwares, click here.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Linksys Wireless-G WRTP54G Router Logo
46 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
