Question about RCA HD52W58 52" TV
Auto convergence the auto convergence option is gone from the menu and all the colors are messed up. My auto convergence menu disappeared and my picture is messed up
    Genius:
  • 1,030 Answers
This point to the special fuse fl231 a small rectangular fusable link. .4 amps if you can get this fuse and you can solder repairs is not to difficult.. you have to resolder connections that cause this fuse to blow
Posted on Jun 24, 2008
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Aug 11, 2010 | Aiwa TV-S2011 20"
Got a used sony 3v36fs16 36". color convergence needs adjustment. can i do this myself?
yes you may need the maual unless the remote has an auto convergence, if you have no manual but can access the convergence menu your goal is to line all the colors up with the diagram
May 16, 2010 | Sony KV-36FS16 36" TV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Manual needed for Sanyo CP29ST3 - I need to tune in TV channels! I lost the manual!
Sanyo has two parts distributors in the U.S. Both are listed below. You'll need to contact the one closest to you and inquire about purchasing a replacement manual. In the meantime, if you're just trying to program the channels into your TV, you need to bring up the TV's menu and select the screen that has the channel or setup options. All TV menus follow the same general format: you should see icons or words going across the top of the screen or down the left side indicating the different menus that are available. On some older TVs you have to press the menu button more than once to cycle through the different menus. Each menu has different options such as picture options (brightness, color, tint, etc) audio options, setup options, and channel options. Use the arrow keys on the TV remote to manipulate what you see once the menu is on the screen. Once you find the channel options, you need to perform what's called a channel scan. On the screen it may say auto scan, auto program, or channel scan. Once you start the scan, you're done. The TV will scan for all available channels and the menu will disappear once it's finshed.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 22, 2009 | Televison & Video
I have a Mitsubishi WS-55807 and the colors started to separate - you can reset it by turning if off and on again and it goes away but in time returns, starts getting blury then the colors split up - just...
In your On Screen Display menu (OSD), you should have a place that says "convergence". As a sub heading to this it will say "Auto-Convergence". This is where you want to be! Hit OK under AUTO, and watch the magic happen! If your set happens NOT to have AUTO, you'll have to do it manually. You're going to make the lines all match up doing one color at a time until all three colors are done! It's not hard at all. It may take a little patience at first, but just think of all the money your saving by not having a TV tech come out to your house and you'll be fine!
May 31, 2009 | Mitsubishi WS-55807 TV
Zenith h25w35dt cant unlock auto program
USE ZENITH REMOTE HOLD DOWN MENU BUTTON UNTIL THE OSD DISSAPEARS THEN HIT 9876 ENTER CHANGE P/L SETTING IN FACT. MENU
Apr 08, 2009 | Televison & Video
Curved screen and double letters
The convergence circuit has a problem. Can you confirm the model number as HD52W58 please? I will double check the requied parts and update this.
Thanks,
Dan
Sep 03, 2008 | RCA HD52W58 52" TV
Auto convergence
this is an indication of a special fusable link fl231 has blown it is a small brown rectangular fuse that blows due to poor lead free solder connections on what is known as a flyback.. if you can solder and can get the part i find this repair to be a simple one... Caution. televs\isions can hold leathal voltages even when unpluged... EXTREME caution should be taken
May 26, 2008 | RCA HD52W58 52" TV
Auto convergence issues
this is an indication of fl231 fusable link has blown.. a brown recatangular special fuse that blows due to poor solder connections on flyback. IF you can get the fuse and can solder this is not a difficult repair... EXtreme caution should be taken with televisions. this set can hold 380 volts even when unpluged.. rember resolder flyback
May 25, 2008 | RCA HD52W58 52" TV
Ts-4557
easy way to adjust the convergence is, first off blue back option. Then check snow on the picture., if each snow carries any color on side. adjust convergence till color disappears. take long time but it is very easy no need other equipments
Feb 08, 2008 | Mitsubishi TS-4557 45" TV
RCA HD52W58 52" TV Logo
81 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
