Question about Panasonic Microwave Ovens
I have a microwave approx 18 months 0ld doesn.t work I need to know where to take it I live in Exeter EX2 4RP
Call Customer support at 1-800-211-PANA (7262) or visit their website at
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances.75542
Posted on Jun 21, 2008
Microwave Sharp R-7E53 built-in Over the last 18
These can be repaired, but if you're not in the US, the extra shipping may make it uneconomical.
The service manual can be downloaded here.
(careful! - the "Get Manual" download link is in the text below the big preview image)
Oct 27, 2013 | Microwave Ovens
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
GE Microwave - JES1456BJ05 - totally dead - less than 2yrs old
had jes1456bj05 go bad in 3 months. ge sent me a new one and that died in 18 months. going to buy another brand this time, obviously.
Oct 09, 2011 | GE Microwave Ovens
Can,t turn the over the stove lighting on
Replace the bulb. If that doesn't work, the "Membrane switch" under the plastic film control panel is damaged. There is no good way to fix them. Contact hotpoint to see if they still have replacement panels available for this model. If not, either live without the light or replace the whole microwave.
Sep 24, 2011 | Hotpoint RVM1625 Microwave Oven
Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
Oct 28, 2009 | Sharp R-353 Microwave Oven
Microwave doesnt power up, suddenly stopped working, can it be the fuse? ow do u check if the fuse is OK?
If there is no power at all then it could be the internal power fuse has blown, there could also be other parts faulty also. I would not recommend you to check this if you are not electricallly qualified as a microwave is a very dangerous piece of equipment to tamper with, even if there is no power to it. It would be best to call a service engineer to check it over for you.
Sep 23, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
MICROWAVE WILL NOT HEAT
In my case I found an additional fuse, a high tension fuse (5KV 0.8A) in a white on-line isolation slave next to the transformer.
The fuse was blown.
I guess replacing it should solve the problem.
Oct 07, 2008 | Microwave Ovens
3 microwave ovens in 18 months - all won't heat up - what is causing the recurring problem?
Carla, Sorry to read of your troubles. Your unit that is only 2monts old should be under warranty, or did you receive any warranty?
What you describe as " the noise one gets when metal is put in by mistake". The noise is Arcing of Microwave Energy. Do not operate a Microwave Oven DRY (without something inside that will absorb the Microwave Energy. A Dry-Run Microwave Oven will feed-back upon itself and do damage.
If your unit is matched to the electric needs, both voltage and cycles, then I would not get another one of the same Model.
Feb 02, 2008 | Microwave Ovens
Microwave Ovens Logo
56 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
