Question about Frigidaire FRS266ZDSB Side by Side Refrigerator
PLHS267ZAB6 Frigidaire Refrigerator
Can you help me find out what part I need. I found two temp controls.
pretsos@sbcglobal.net
  • Anonymous Dec 12, 2008
    freezer freezes frig doesnt cool
    Scholar:
  • 149 Answers
Theres one for the freezer and one for the refrigerator what seems to be the problem so i could pinpoint which one to change
Posted on Jun 21, 2008
Snowmaster BD60DE keeps on beeping while doors are shut
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
The fault warning sign is beeping when i open the fridge door
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Hey my Samsung cooltech plus is making beeping noises fridge temperature is jumping from one temperature to another while the beeping noise is going on. Can anyone please help me thank you
Read more :
Feb 14, 2017 | Samsung Refrigerators
It will NOT stop running. Temp set at 37 goes to 34 Freezer set at 0 goes to 4
Sounds like the thermostat (cold control) located in the ref <br /> needs to be replaced. <br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a>
Aug 31, 2010 | GE Profile PDS22MHR Bottom Freezer...
Water leaking from under the fridge
Check drain
This is a sympton of a defective refrigerator cold control (Thermostat) getting too cold and freezing drain
Also check temp of freezer should be below 10 degrees
Aug 07, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Jan 20, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
Dec 15, 2008 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire FRT 22INLHW3 Top Freezer Please help?Freezer works fine, the automatic ice maker works fine but the refrigerator temperature stays at about 50 degrees and up and gets warm, I have cleaned the...
hi thanks for the question the freezer will work kind off ok, even if the fan in the freezer is . not working . check that check for frost on the freezer wall
Sep 29, 2008 | Refrigerators
Hello Guest...the easiest way to see how the thermostat is installed is to get the parts diagram from Frigidaire, using the model number. It shows you how the control panel is put together. Holler back if you can't figure it out. Just trying to help! :)
Jun 20, 2008 | Frigidaire FRS266ZDSB Side by Side...
Fridge is too cold
do a test put the fridge on 1 or 2 (the warmest settings) if you don't see that it turns off you have a defective thermostat. there pretty easy to buy and to install if you need assistance just feel free to e-mail me @ hvac.tech7872pr@gmail.com
Jun 15, 2008 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire FRS266ZDSB Side by Side Refrigerator Logo
218 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
