FixYa.com
Tags:
BenQ PB6100 Multimedia Projector
Blue screen (by 2 users)
posted by lvlcontactus on Jun 20, 2008
When I turn on the projector, it comes up with the BenQ logo. After that there is just a blue screen. It usually has the option to select a source, but none of the controls work, it won't do anything. I have tried with and without hooking it up to other devices, restarting etc, nothing helps.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 24, 2008
Exactly the same as lvlcontactus. Is this the same as the white screen problem described in the fixed problems?
Best Solution
posted on Jul 25, 2008
FixYa! (100)
dhoulbrooke
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
Hi Guys,
I recently struck this issue with one of our PB6100's. To resolve I did the following:
  1. Enter service menu (found on AVForums): PRESS AND HOLD UP BUTTON UNTIL LAMP HOURS ARE DISPLAYED, PRESS THE POWER AND BLANK BUTTONS TOGETHER
  2. Under the Fan menu select "More Options". You should then be in the "Fac7 Submenu".
  3. Select "Hard Reset". Note that this will reset the lamp hours also!
  4. Power off & then on again. Test input.
The above worked for me. Hope it helps.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projectors problems?
pb6100
Did you ever find out the... Answer This...
Hi there
Problem With Benq PB6100 the...
About 8 Out of 10 times when I... Answer This...
dust in the lens mechanism
i have problem with dust in... Answer This...
Cleaning dust and dirt from the...
How do you safely clean the... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
