Pump Testing How do I test the pump?
  • lintcollecto Jun 20, 2008
    And thank you, I was going to start messing with belts or bearings.
  • 487 Answers
Take the hose of of the pump and clean the inside than start the drain cycle. Not ronse lol than you will be wet.
You'll normally will hear staight away if it is the pump.
If clogged clean if broken give me the brand and model number and I will see where you can get your part the cheapest
Posted on Jun 21, 2008
2001 ford f150 v8 had problems with intermittent engine shutdown. After letting it sit for half to hour half it would start up. Replaced the fuel and pcm relays, the fuel filter and the fuel pump.
Replaced the fuel and pcm relays, the fuel filter and the fuel pump.????? Your guessing not testing . Did you do fuel pump pressure an flow testing before replacing those parts . How about fuel pump voltage drop testing ?
Testing Electric Fuel Pump Problems with Voltage Drop Test
Besides it doesn't sound like a fuel pump problem ,sounds like electrical problem or electronic problem . What's missing after it shuts down ? Spark or fuel . Testing an not guessing is the key to finding the problem . Hooking up a factory or professional type scan tool to view engine sensor data parameters an checking to factory spes.
046 Engine Hard to Start or No Start Scan Data for No Start
Any sensor when hot can cause these type problems .
Sep 21, 2017 | Ford Cars & Trucks
Hit a hole and the gas tank bottomed out and the fuel pump quit working but the plastic tank is not ruptured do I need another pump or just reset it. It is on a 1999 Chevrolet venture
Chevy doesn't have a reset switch . Test the fuel pump electrical circuit ! Here is a link to a video on youtube testing GM fuel pump circuit . Before condeming the fuel pump test.
GM Fuel Pump Relay Testing
May 29, 2017 | Cars & Trucks
Pont gran am 2002 wont start cant hear the fuel pump when pump on car start then runs for half hour then stop is it key switch
To say it is a key switch problem without testing would be a guess , an guessing isn't the way to do proper automotive diagnostic's . If you don't know how to do electrical testing on fuel pump circuit , I suggest you take your vehicle to a qualified repair shop or learn automtive electrical testing . GM Fuel Pump Relay Testing
Nov 05, 2016 | Cars & Trucks
So if could be I bot a faulty pump two weeks ago
That can happen, especially today with "made in china" (or wherever) parts. Do or have some electrical testing done before you condemn the pump though. Is this a fuel pump?
YouTube has videos on electrical testing of the fuel pump circuit. You will need a voltmeter. A digital volt-ohm meter (DVOM) is a multi-meter most used in auto testing. A Fluke brand is most expensive, but many brands are quite inexpensive. I have used a Sears Craftsman multi-meter for several years, only paid about $30 for it-works great.
Is the pump inside the gas tank? Then definitely do the electrical tests to see if your pump is the problem.
Oct 31, 2016 | Cars & Trucks
I can't get the fuel pump out of my 04 Cadillac DeVille
Why not ? did you pull the fuel tank out . Or you can't figure out how to get the locking ring off . An you may want to watch this video on testing a GM fuel pump electrical circuit . Not to say you did but a lot of people on here assume it's the fuel pump replace it without testing the electrical circuit . GM Fuel Pump Relay Testing
Jul 11, 2016 | Cadillac Cars & Trucks
How do I reset the fuel pump shutoff switch in a 2003 Chevy impala?
There is no fuel pump shutoff switch . Here check out this video on testing GM fuel pump electrical circuit . GM Fuel Pump Relay Testing
Jun 26, 2016 | Cars & Trucks
2000 chevy venture. wont start. change fuel pump runs perfectly for one day. next day the van start and drives out of driveway sputters and dies. starts and sputters back home. change the fuel censor. ...
Testing is the way to a fix . Fuel pump pressure testing , electrical testing . Viewing engine sensor data on a scan tool . Instead of guessing as to the problem learn to test or take it to a qualified repair shop . Changing ECU without doing it correctly can cause problems that were not there before . PCM - engine computers need to be programmed , dealer only.
048 Engine Hard to Start or No Start Scan Data for Starting Problems
Jul 07, 2017 | 2000 Chevrolet Venture
1999 Grand Prix GT 3.8 won't start. Fuel Pump?
Testing fuel pump pressure an doing fuel pump electrical circuit testing should be done rather then guessing . Could have electrical problem that mite make one think it was a bad fuel pump . A couple simple test's to confirm , before replacing an finding out it didn't fix the problem .
Plus the fuel pump is controlled by the PCM - engine computer via a fuel pump relay .
Fuel pump electrical circuit diagnosis no fuel pressure testing GM
Oct 29, 2017 | 1999 Pontiac Grand Prix
1999 Chevy S-10
Rather then just thinking the fuel pump is the trouble ,test ! Fuel pressure and flow testing . electrical circuit testing , voltage drop testing . Test don't guess !
What engine does it have 4.3 vortex engine with Central Sequential Duel Injection Fuel System ?
If the fuel gauge wasn't showing the correct level you replace the sending unit , not the fuel pump . Two different thing's
Fuel psi less than 50 psi no start GM CPI Vortec
Sep 13, 2017 | 1999 Chevrolet S-10 Pickup
Washing Machines Logo
Top Washing Machines Experts
