Question about KitchenAid KCM511 Coffee Maker
Err2 message hi, the problem is with my coffee machine and it all started when the water overflowed when i forgot to put in the coffee pot after starting it. i tried everything, but nothing is working. i turned it on and off all the time, but i keep getting the same message.
  • wedn_blows Oct 26, 2008
    adf
    could it be a recall?
  • 231 Answers
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting!
To clean hard water deposits from a coffeemaker use distilled white vinegar. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinegar and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Posted on Dec 27, 2008
2 Suggested Answers
  • 145 Answers
SOURCE: Kitchen Aid coffee maker err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a few seconds.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
Error 2-Unit will not heat or brew. Stopped in middle of brewing cycle and flashed error 3 code. After unplugging unie and plugging back in an error 2 remains.
Error message 2 is a result of the water heating element burning out. The element is replaceable, if you can find a vendor who sells the element assembly. Price of a new element may be more that a new pot though, if you're lucky enough to find a parts vendor that sells one.
Dec 18, 2009 | KitchenAid KCM511 Coffee Maker
My Survival Guide To The Dreaded Err2 Disaster
Thank you, have a nice day.
Aug 30, 2009 | KitchenAid KCM511 Coffee Maker
Bunn coffee pot blows water out top of basket
Check the grind on the coffee, brew a pot without coffee and if it overflows, then the machine has a problem. If it doesn't then try a coarser grind on the coffee.
Jun 14, 2009 | Bunn Coffee Pots: Thermal Carafe
Apr 07, 2009 | KitchenAid KCM511 Coffee Maker
Cleaning advice of this maker seems necessary
Start cleaning process with vinegar, several times.
Mar 27, 2009 | Bunn VPR Coffee Maker
Pumping more water out than what i put in
This coffee maker uses a resevoir tank system - the water you pour in pushes out water that is already heated - the water you pour in won't actually be used for that pot of coffee! For that reason you should only use full pitchers when filling. You may need to cycle through 2 or 3 fillings before the input matches the output once more. The capacity of the resevoir is about 3 pitchers; you can brew 2 pots in a row before the machine needs a break to bring the resevoir back up to temperature.
Nov 12, 2008 | Bunn VPR Coffee Maker
Err nessage 2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Aug 19, 2008 | KitchenAid KCM511 Coffee Maker
Err2 appears on display when I turn on coffee to brew I have turned off and on, unplugged did everything still error message
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafeand fill carafe the rest of the way with water. Run that vinegar/waterthrough machine. Using another container, fill machine with plain waterand run that through. Repeat until the vinegar taste is gone. If you donot run lots of plain water through the machine after, your coffee willtaste like...um...disgusting! Also, use a spell-checker beforeimproving this posting.
To clean hard water deposits from a coffeemaker use distilled white vinager. You may need to use as much as agallon if the scale buildup is really bad. Fill clean coffee pot onehalf full of vinager and run through machine as if making coffee.Repeat this process several times using fresh vinager until it comesout clear. Do this once a week and your maker will work much better.
Jul 21, 2008 | KitchenAid KCM511 Coffee Maker
KitchenAid KCM511 Coffee Maker Logo
236 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
