Question about Panasonic Cameras
When switched on the camera lens comes out and then it says switch off and then on again when switched off the lense will not retract this has happened straight out the box it is a dmc-fs5 tried resetin whole unit to no avail
  • 75 Answers
Make sure you are using the right kind of batteries. Not just the size (AA for example), but also check to see if the device needs Lithium batteries rather than Alkaline, for example). This can cause the issues that you see. Check your user guide for details.
Posted on Jun 20, 2008
I can't get rid of 'Lens Error' message and keep my camera switched on for more than a minute.
You don't need to drop a camera to get a lens error. Could be anything, from holding the camera in a wrong way (touching the lens barrel) or a bit of dust in the barrel or a gear, or a gear that breaks off. If the lens retracts correct when the camera is switched of, and comes out to the full extend when it is switched on, you should think everything is in working order. But when you say, the screen looks ver blurry that could be an indication, the lens is not coming out correct, or the focus mechanics does not work correct. I'm afraid you have to bring the camera in to a service centre (or buy a new one) if you can't solve this, by again take out the battery, charge the battery and reinsert the battery.
Jan 26, 2014 | Nikon COOLPIX S3300
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
Usually a result of a lens jam or some dirt/debris/sand getting into the lens mechanism.
Not much you can really do about it except to have the lens replaced. There are
some ideas to temporarily fix the problem, but it will probably happen again.
If you suspect dirt/debris or jams were not the cause then maybe the lens just needs
to be reseated.. just gently tap the side of the lens with a pencil and keep your fingers crossed
Jan 23, 2011 | Sony DSCW320 Digital Camera
Lens will not retract after being
the problem is that the lens is out of alignment. if its not making grinding sounds try manually help the lens to reseat itself. if that doesnt work its not ecomical to repair unit cuz parts and labor are about 120-130 dollars.
Jun 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber-shotdsc-w50 lense won,t retract when switching power off. when switching on screen message displays turn power off and on again
you must reset the lens this means taking the camera apart and reseting the 423-790-1480 and I'll explain whats envolved.
Sep 24, 2008 | Cameras
My sony dsc h5 camera lens wont open/focus
This might be a problem with the lenses' mechanism... Maybe you hit the camera (having the lenses extended, eventually). You have to pay a visit to the local service.
And in the future, use the protection that came with the camera (the black cilinder). It protects the lenses and also offers you the possibility to mount the lens cap without having to switch off the camera.
Jul 27, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
FZ18 Lens Cap error message with telephoto converter
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
Mar 21, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
The lense does not close in
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 03, 2007 | Samsung Digimax S500 Digital Camera
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Cameras Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
