Question about Samsung HLP4663W 46" Rear Projection HDTV
My DLP TV wont turn on.
My tv won't turn on, I have already replaced the ballast and the lamp. Well I checked the color wheel and it wasn't spinning when I push the power button. I checked and the color wheel is getting power.I removed the color wheel and when you spin it by hand it has a dry metal to metal sound, but it still spins freely.
Do you think the color wheel is the problem?
Thanks
  • cschleif Oct 08, 2008
    My DLP won't power up with a picture. I just replaced the lamp and I still get the three blinking lights on the power button. When I unplug the TV for 2 to 3 minutes then the picture shows up. If the Ballst or color wheel were bad then I'm assuming I wouldn't even get a picture. I shouldn't have to unlug the TV and cable box everytime I want to turn on the TV. And advice. It seems the Samsung support peole are idiots and have no idea how to help.
As part of the power up sequence on the Samsung HLP-4336W the lamp isn't turned until timing pulses are detected from the color wheel. The color wheel motor is powered through the flat brown four conductor ribbon cable and the timing pulses are detected over the the three conductor ribbon table.
Posted on Jul 06, 2008
Samsung hln617w TV Dlp lamp won't turn on already replaced lamp, ballast, color wheel
It sounds like the main power supply has a bad capacitor. its a typical issue with a lot of electronic. look on the main power board that the outlet cord comes in to the TV and check all the cylindrical components for swelling, leakage, or singe makes.
Dec 13, 2013 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLM-617W/XAA
with lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
Jul 18, 2008 | Samsung DLP HL-P5663W 56" TV
I need help with my DLP TV
If you have verified the votages are there at the color wheel and its not spinning the color wheel is most likely defective. the sound you hear when spinning by hand is most likely the bearing but that shouldnt stop it from spinning. but as i said if the supply voltage is present but it still wont spin. the color wheel must be defective.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Can you help
Hello Brandon B
Great Job at trying to fix your own TV.....Bravo!! Ok, you may very well have a bad Color wheel. You have already change your Ballast and Lamp. The lamp would have been my first step. If you have a defective color this will surely cause the set not to come on. The DM board detects what going on with the color wheel and will not start the lamp. There are 2 types of color wheel listed for this TV.
List price $100
BP96-00674A COLOR WHEEL (FOR TYPE L3 VERSION PW03 UNITS)
List price $100
BP96-01103A COLOR WHEEL FOR TYPE L6 VERSION PU01 UNITS
Best regards
circuitcity
TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
I need your help with my DLP TV
YOU PROBABLY NEED A DMD BOARD. THE COST OF THE BOARD IS $900 . YOU CAN GET A LIGHT ENGINE FOR $700 THAT HAS A NEW LAMP, COLOR WHEEL, BALLAST AND DMD.
WHAT A DEAL . THERE IS A $400 CORE ON IT SO YOU WILL HAVE TO SEND BACK YOUR NEW BALLAST AND LAMP TO GET THE CREDIT BACK.
WHEN I GIVE A QUOTE ON THESE SETS FOR REPAIR MOST OF THE TIME IT EXCEEDS THE VALUE OF GETTING A NEWER BETTER SET.
DON.
Jun 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
179 people viewed this question
Henry  Thomas
Henry Thomas
