Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Sandisk micro hey there. i tried on your instructions. im already in the "computer management" area, but i cant find the "right click new partition". please me message me at milkcookies1025@yahoo.com thanks so much. -jamie
    Scholar:
  • 180 Answers
You should be in the disk managment area
my computer---right click-------manage--------- disk managment------ and see for your disk there---right click---- add new volume......
Posted on Jul 29, 2008
Error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
My sandisk 1.0 GB memory card with a lock switch on the side, no longer has the switch when i tried to unlock it the switch came off. what can i do to unlock it
1.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 2.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 22, 2010 | SanDisk 1GB microSD Memory Card
I accidently deleted the partition with my cruzer
Ok turn on PC, and have that drive plugged into the usb port. Find your my computer icon, right click on it and goto manage in the menu. This will open the computer manager, in the list on the left you will see disk manager under Storage. Click on disk management, in the window on the right you will see the different Hard Drives and Storage devices there. Look for the one that does not have a drive letter and may state unknown. Right Click on the device and Mark Partiton as active, then also format the drive. Viola! you should now have your Pen Drive showing up under my computer.
Oct 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My 4gb sandisk cruzer micro cant be formatted help pls
connect your flash drive to pc then goto mycomuter right click on it goto manage the window appers then go to disk management their are showing your hardisk and cd rom & flash drive connected with your computer then right click on your pendrive then formate it using formate option
Oct 01, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My memory card corrupted by my pc simply because im not safely eject hardware. i accidentally format it now from 1gb turn to 128kb..how can i restore to 1gb pls help me..thanks..
Connect your sandisk to computer thne right click on my computer icon then click on MANAGE then clcik on disk management then you find removable media you see there unpartitioned space of your sandisk .
Just right clcik on it then create partition .
Then check.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | SanDisk Extreme USB 2.0 Memory Card Reader
My 8gb micro cruzer flash drive has been unformatted.
i)let me suggest i ur able the flash drive icon when you go in desktop or my computer then right click on that drive and click the option format and follow instructions, if you are able to format successfully, then no worries if formatting is not done.....
ii) then try to keep your windows'xp or vista cd in the cd tray and restrat system and follow the procedure formating system(i'm not saying to install or reloading a pc), when u reach a position where u see all the partition(like c, d ,e drive ... with memories), u will also see the flash drive partition along with hard-disk partion separately...
now click on the flash drive partition and press the button D to delete partition and follow instruction after do this , press C to create partition and u will see that a letter(e, f..) will be given to our flash drive....
now quit xp (by pressing ESC, donot proceed loading XP or vista) and now restart system and i think ur flash drive will work.....
Dec 30, 2008 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk cruzer micro 4GB
it may be because of the usb port of the system or the usb of the pendrive.................
Feb 08, 2008 | SanDisk 4GB microSD High Capacity Memory...
I can't Access my Pen drive,  My computer is Saying that i need to Format it and when i try the Computer can't. I was Formating my Hard Disk Yesterday and i forgot to eject the Pen drive, could that...
you have deleted the partition by the sound of it, I accidetly done it once.. try this
click start, right click on my computer and go to manage.. then double click on storage, disk management local.. and it should show up here, once you create a new partition on it, format it and your all set..
Hope this helps!
Dec 16, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer Scan disc won't access information
Maybe one of you have deleted the partition on the flash disk... this is only likely though if you re-installed operating system or were chaging partitions..
if so here's a solution
click start, right click on my computer and go to manage.. then double click on storage1.gif, disk management2.gif local.. and it should show up here, once you create a new partition on it, format it and your all set..
Hope this helps!
Nov 30, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to format
1.run...cmd
2.Format F:/fs:Fat32 [ F should be change to flash drive name]
3.enter ....wait the results
Click Ads in my web for thank me at www.review1.net
Oct 29, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
42 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
