Sharp tv dish network
I'm turning both off,tv is in the bedroom and when we leave room we turn off everything
  • 197 Answers
Ok...try it with just turning off the dish system, leave tv on. let's eliminate one of the components from the formula
Posted on Jun 20, 2008
Why does the sytem has to re-start every time I turn on the tv in the morning?
Why is the receiver being turned off . I never turned mine off just used the Tv on/off
Sep 26, 2017 | DISH Network ViP 922
Bedroom remote doesn't work
weak batterys wont hold codes on it huh?
Sep 24, 2012 | DISH Network Televison & Video
I have one receiver in my living room. The living room tv is on the #1 channel and the kitchen, guest bedroom and master bedroom tv's are on channel #2. All remotes were working just fine and suddenly...
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
http://www.dishnetwork.com/SupportSection/remote-setup
Daniel Busa
DISH Network Customer Service
Jan 04, 2011 | Universal Remote Control DISH Network...
I have anrca hdtv model # R56WH76 and I don't know how to set it up with my cable. I have the dish network box in the living room but this rca tv i have in my room with the cable coming out from the...
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Dec 19, 2010 | RCA R56WH76 Projection Television
I am trying to set up a show to be recorded in my living room. But it records it to the other reciever in the bedroom. I would like it to record to the living room receiver but it won't. It automatically...
Hello! Daniel Busa with Dish Network here! Most likely your reciever is using our record plus feature. This sets the record default to always being on tv1 or always being on tv2. To fix this hit menu 8-5 go to disable hit select, go to done hit select delete the timer and set it up again.
Aug 23, 2010 | DISH Network ViP722 DTV Receiver /...
I HAVE DISH NETWORK HOOKED UP IN LIVING ROOM, I WOULD LIKE TO ADD IT IN BEDROOM OFF OF THE SAME RECIEVER. I USED A SPLITTER, THE PICTURE IN LIVING ROOM IS CLEAR, BUT REALLY FUZZY IN BEDROOM. I KNOW THEY...
You will need to split the signal with a 900mgz splitter between the living room and other room. if your pic is fuzzy you have a bad splitter or bad cable, try replacing these one at a time and it should clear up. If your getting a sat pic but ti is fuzzy its for sure in the line somewhere fro teh splitter.
Nov 16, 2009 | DISH Network ViP 612
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
Universal remote
only a uhf remote will work from that location, you will probably need to get a dish network 6.0 or 6.3 remote
Jul 04, 2008 | DISH Network 322 DTV Receiver
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
