Question about Microwave Ovens
Logitch webcame did not download on windows vista
G.E.convection oven (modle # jvm193 ,serial # vh9480845) blow a 15amp., 250 volt fuse.Replace the fuse. The new fuse lasted about 3 sec., where do I look now.
Posted on Jun 21, 2008
How do i put the baffle back into the door part#AP5061204
To zig107 RE: LMV2053XX
A lot of times it's easier to set the microwave on its left side, then open the door and work on it.
That way, gravity will help you keep things in place.
Assuming this is an over the range model, you'd have to pull the oven from the wall. Refer to your installation instruction booklet for details.
If for some reason you don't still have yours, you can order it as part number 3828W5U0492 from the Pros here.
You can download the owner's manual here.
You can download the service manual by clicking the text link below the document preview on this page.
Be careful where you click on that page (which is not mine). Please follow the download instruction above.
Jan 21, 2014 | LG LMV2053 Microwave Oven
Tip
How to uninstall program from my DELL computer
Questions people asked:
1 How to uninstall program that’s not showing up?
2 I go to add/remove programs and want to uninstall program. It says “error, can not delete the program”, how can I remove it from my DELL computer?
3 I recently install McAfee and my computer gets a Blue Screen, Should I uninstall it? How to remove it from Control Panel?
You may face stubborn program of uninstalling an unwanted program especially it is an anti-virus.
How to remove corrupt programs from your computer in one minute? You can get the best solution to remove a program completely from your PC.
Add/ Remove Programs utility usually helps you remove programs from your computer. Unfortunately, it can only find common program install on your computer. It can not show hidden programs and some malicious programs such like windows messenger, vista protector, Norton anti-virus 2006, etc.
You can not remove anything if you uninstall using Control Panel. Every time you install a program, your registry entries will be modified. The residue can be the causes of Blue Screen, computer freezing, DLL error and computer slow. If you want to remove programs completely, you should also remove associated registry entries. It is also the best solution to remove corrupt programs.
Get rid of programs which combine well with the operating system:
Troubled with uninstalling programs? Don’t worry! You can solve it in one minute. ErrorFix integrate with Windows registry fix tool, uninstaller, invalid file removal and IE restore program.
Download this excellent uninstaller now.
With this software, you can forcibly remove a program even it is running. Why not experience this wonderful software? You don’t have to get more computer savvy.
on May 26, 2010 | Microwave Ovens
Webcam saos
I had the same problem. When connected on Skype you have to go to the menu ont he top left corner of your screen and select "tools". When the menu rolls down the option fourth ont he list is video settings. Click on that and you should be able to see the image on your laptop camera ...if it is working. If not then the camera itself has a problem with which I am afraid I cannot help. Good luck!
Oct 06, 2013 | Microwave Ovens
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
Where can i find an owners manual for a sunbeam Mixmaster Vista food processer?
good day
here is the manual of your food processor...
just click it
http://www.retrevo.com/samples/Sunbeam-manuals.html#Food%20Processor
and choose the model then click again
after that,download the files to see the manual..
thank you and good luck
Apr 10, 2011 | Microwave Ovens
I want to type chinese and chat with my family
If you have a windows OS download the language pack that you require and off you go.
Hope that helps.
Mar 01, 2011 | Microwave Ovens
I need software for sch-f339 dc16 compatable to windows 7
Always get your drivers from the manufacturer of your Laptop, Notebook or Desktop.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Feb 09, 2011 | Microwave Ovens
Manual for kenmore gas range 790.77483804
Go to http://www.searspartsdirect.com and enter your model number in the "find it fast" window and choose model search to the right of that. This will bring up your gas range. On the right side of the page it says view manuals. Clicking that will bring up 2 manuals. Product guide and Installation instructions. Click on product guide and view or download your manual. You can download it by rt clicking view manual and save as.
Thanks for choosing FixYa,
Kelly
Oct 01, 2010 | Microwave Ovens
Unable to set clock and or operate
You can go too the manufactures web site and download the manual for free as long as the microwave is under warantee............
May 02, 2009 | Microwave Ovens
NEED OPERATION MANUAL FOR 1998 MICROWAVE-CONZECTION OVEN mODEL JVM1190BY002
Go to geappliances.com. Select "Use and Care Manuals" under the Search drop down menu. Type in your model number in the adjacent window and select "Go". Your manual is available in a downloadable .pdf format. I hope this helps you.
Jul 23, 2008 | GE Microwave Ovens
Microwave Ovens Logo
47 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
