Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Amp Problems I'm asking this question for my boyfriend, so I hope i explain it well. Basically somehow the positive that runs from the amp to the battery somehow got loose and came off the battery and touched the negative side of the battery. My boyfriend believes he has blown his entire amp. The hifonics light no longer comes up and he says the power light isn't on neither. Is there someway we can check whether the system is blown, or if the amp possibly went into protection mode or SOMETHING. Thanks
  • 631 Answers
He needs to confirm that he has both B+ and remote turn-on voltage at the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jun 20, 2008
Why when i hook up an OBD2 code reader it doesnt come on at all like its not gettin power
If you have codes DO NOT CLEAR THEM
You will loose ALL DATA needed to find & resolve
any problems
You do not reset anything-you CLEAR DATA,Emission
Monitors,& Freeze Frame Data, that can tell you what happened
when a code or fault was set
If you clear codes, they will come back,as soon as the motor
is restarted ,or when those emission monitors run next time & do
so for a number of key cycles or until the problems are fixed
Forget Relays ever existed. They are like a plague that has spread
thought the internet
Please Google relays & learn what they are,They seldom fail &
NO Parts get replaced EVER Until a vehicles system has been
tested & a part fails a test
You DO NOT hang parts or throw parts at any vehicle
Only people with NO Vehicle knowledge do that, most folks
do that ,even some professionals at repair shops ,to the tune
of 3 Billion Dollars a year world wide in perfectly good parts
Explain in detail all of your vehicle problems
Explain what codes reader you have & what your doing
You plug it in under the dash & turn the ignition to the on
position & write down the codes, then push the up or down arrows
to see the next one
Read the codes reader manual
After that you start the vehicle & drive about 10 miles to see what happens--- with the code read still plugged in
If you could care less about fixing it ,clear the codes & see if the
same ones come back.
Once done ---you start all over at a repair shop & use professional
tools to do it correctly & find a problem
Jul 19, 2014 | 2002 Chevrolet TrailBlazer
Reduced power
APP (accelerator pedal position) sensor is bad. Basically means you can floor it, but the signal going to the computer is only a reading a fraction of what it should, which in turn gives you the decreased power. You will need to replace it (basically the entire gas pedal assembly). I've seen them run anywhere from $60 to $120 new, depending on where you go, so shop around. Or, if you're comfortable enough buying used & have basic knowledge of hand tools (or know someone who does), go to a junkyard and pull the entire gas pedal assembly out of a scrapped Impala (make sure its the same year). They run an average of about $25 + tax here in TX, but I imagine that varies from state to state. All it is, is 2 bolts holding the assembly to the floor pan and either one or two wiring harnesses (sorry, it's been a while since I did my wife's & I can't remember for sure). Simply disconnect the wiring harness(es) (you may need something like a philips head screwdriver or something to depress the little latch to get the clip out that hold the harness securely in place) & remove the two bolts with a socket wrench. Then bolt the new pedal assembly in place & reconnect the wiring. After that, you may need to clear the code in the computer. This will get the messages and lights in the dash to turn off. Just take it to a dealership or local mechanic (any of them will have an ODB2 diagnostics tool) and ask them to clear the code. two minutes later, you'll be back on the road and the car will be running like new again. Hope this helped... Good luck!
Dec 25, 2013 | 2007 Chevrolet Impala LS Sedan New Cars
Car runs hot
That is just a statement & in no way explains
any issues
It also doesn't say what is getting hot,motor,brakes
inside the pass cabin !!
No one can guess at an answer if you have not
do some form of testing & can provide results of
what you have found & have or don't have
Basically you need a car to test drive & work on
Aug 27, 2013 | 1998 Lincoln Continental
2000 ford mustang electrical problems
You have a open connection somewhere,do you check the fuses especially the fuseable link at the positive battery post how about the power at the ignition switch it hot at all times,your disconnected somehow you might have to make a jumper wire to find what opened.
Mar 20, 2012 | 2000 Ford Mustang
How do I wire two subs up for the full 850 rms on a kac-9102d amp
  • Wire up two 4 Ohm subs in parallel (bridged) or one 2 Ohm sub.
  • You will take both of your subs positive leads and run them to the left positive (white connector on the amp) and both of your subs negative leads and run them both to the right negative (gray and black connector on the amp). That's max RMS right there. Pay attention to the Ohm rating of your subs as this does play a factor. What I explained is how to bridge two 4 Ohm subs. 8 Ohm is a little different but car subs rarely are 8 Ohm.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Kenwood KAC-9102D Car Audio Amplifier
Following a split from my boyfriend I really need some help in how to connect up my hifi system. It's all technics Tuner Receiver ST 610L Equaliser SH GE70 Amp SU V470 CD Changer SL...
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Jun 14, 2011 | Technics SH-GE70 Home Equalizer
My 1995 chevysuberban has no speakers and would like to know how to wier the speakers in my car?
The car is not important .Connecting speakers to any unit is basically the same. there should be a color coded wire harness connected to your head unit. The speakers are as such: White & White with black stripe (Front Left) Grey & Grey with black stripe (Front Right) Green & Green with black stripe (Rear Left) Purple & Purple with black stripe (Rear Right) The Solid colors are (+) Positive and the Stripes are (-) Negative. Connecting any one of these incorrectly will result in phasing problems. Hope this helps. dreamsystems
Feb 09, 2011 | Car Audio & Video
What is the best way to wire two alpine SWR 1222D subs to a alpine PDX 1000 1
First off excellent choice on audio equipment, i guarantee you won't be disappointed. So your subs are dual coil 2 ohms. So wire each individual sub in series. If you don't know what this means i'll explain. On each sub there are 2 sets of wire terminals. Connect a wire from the one set's - to the other set's +. Do this on both subs and you will have the coils wired in series making each sub 4ohms. Now to hook the subs together you'll need to wire them in parallel. Now since you have your coils in series, on each sub you have one + terminal and one - terminal left. So run a wire from the + terminal remaining on each sub, and run them to your amp. Splice the ends of the two wires together and plug them into the + speaker output of the amp. Connect the two negatives in the same way and plug them into the - port on the amp. You will now have your amp running at its desired 2ohms. When wiring this disconnect the fuse on your amp power wire to avoid short problems. And if you get confused at all, and aren't sure what to do, ask again don't guess, if its done wrong you could severely damage your equipment. Hope this helped, enjoy the bass...
Sep 16, 2009 | Alpine Car Audio & Video
Bought the Q7 mic .. doesn't work with my G-Dec Junior Fender Amp
If your amp has 2 inputs, you will need to rewire your standard mike cable as follows. Go to for the wiring diagram. If you aren't comfortable with doing this go to a music store and explain your problem and ask if they have a low to high impedance adapter with an XLR on one end and a 1/4" plug on the other. Hope this helps.
May 23, 2009 | Samson Q7 Professional Microphone
All right I'm having EXTREME problems with my car stereo. Not only have I talked to several car stereo advisers, and also mtx advisers I have also talked to Crutchfield advisors and no one has solved my...
Don't give up yet, I'm sure we can find an answer. With car audio, as with any do it yourself project there may be just some small thing you are missing.
Oct 10, 2008 | MTX Car Audio & Video
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
118 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
