1991 ford 250 horn doesn't work can't figure out
First, hook a test light to the power wire on the horn, push the horn button, and see if you have power there. If you have power, the problem is the horn itself. Maybe even run a jumper wire to the horn, and see if it will blow. Sometimes with these older trucks, it just as easy to change the whole steering column as it is to find the problem. (if you can get a column from an auto wrecker cheap) It will likely be a broken wire in the column somewhere, ususally near where it tilts.
