I have a sharp lc32d64u tv and a dish hd reciever. i programed the remote for the dish and it works fine but when i turn it off then on the remote will not work. dish sent me out two new remotes and a new reciever but it still doesn't work. i read on line that the tv is the problem not dish problem
  • 13,433 Answers
There is a problem in the device memory it seems to reset every time the power is turned off, you have to get a tech to inspect the set. Im not sure about your device but it may simply be a empty memory battery inside.
Posted on Jun 20, 2008
    Sergeant:
    Champion:
  • 230 Answers
Ya the problem is only with the tv may be your tv doesnot support that dish , so give the tv to a service center . if you have warranty then go for it
  • 197 Answers
What are you turning on and off? the dish, the tv, or the remote?
Remote will not work for t.v or dish reciever but batteries are good, lights still work but will not turn tv on or off or turn reciever on or off or even get a guide menu. please help
albertmjuras
Is this a new remote or the existing one? I have provided instructions on how to program the remote to your TV and to readdress the remote to your receiver. Select the model of the receiver you have, click on the link and the just follow the directions. The bottom portion of the page has links for TV codes to program the remote to your TV. If this doesn't work, you may need a new remote. I hope this helps.
Program remote to TV and receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Mar 01, 2011 | DISH Network IR Remote Control
Have to manually turn on tv when turning on digital converter box
astoner3,
Our dish remotes are compatible with most TV manufacturers. On some older TV, we may not have codes that allow for full functionality for the DISH remote. I have provided the most common codes to work with the Sharp TV. The codes are: 628, 605, 740, 591, and 606. I have also provided instructions on programming the remote to the TV.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
May 15, 2010 | DISH Network EZ Remote Remote Control
Just got 46" lcd sharp tv with hd dvr dish reciever on display it shows it has 480p how do i get 1080P
If your dish receiver can receive 1080p then you will get it, if it doesn't then probably the most is 720p/1080i. Check the dish resolution.
Dec 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
DISH remote will not work for the first 10 minutes when the TV is turned on; so, I have to watch the channel I was watching before I turned the TV off. It seems to work fine after the initial 10 minutes.
Is the TV new? Is it a HD TV? If it is Either a 9Samsung LN(R/S)## Series , Sony Bravia/XBR# Series ,Sharp Aquos (New Models) , or Phillips ##PFL Series than the issue your haveing is what we call IR Remote Response Lost. its a light that cuts on and off that makes any IR remo not work some period of time. You have too call the TV manufactuer or use the manual for assistance. If you need details on how too fix it let me know!!!
Nov 01, 2009 | DISH Network IR Remote Control
Need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
Jun 02, 2009 | DISH Network IR Remote Control
I can't change channels,message on TV says,'' no input available''.
Have you tried reprogramming the Dish remote with the Sharp code? That might bring back the TV control. Another option is to use the TV's control panel menu button (if available), go to the setup choices and have the TV scan for channels while the Dish receiver is on. It will find channel 3 then, and probably nothing else, so the set will stay on that channel.
Mar 20, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp tv dish network
that maybe the case..you could put a shielded barrier(copper coated poly) between them.sounds like it's a little too sensitive
Jun 20, 2008 | Televison & Video
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Jumbo Universal TV Remote (Sharper Image-Innovage)
sharper image jumbo remote can't get it to program my philips/magnavox tv.
Dec 25, 2007 | One For All URC-9910 LCD Remote Control
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
