Question about Grilling
Brinkmann BBQ HI, following a minor cleaning of the interior and grills my bbq, i have trouble lighting the main burner (middle), and when it does light up, the flame backs up toward the knob. The other two (L&R) light up no problem with a fireplace lighter independently, its the middle I need. is it blocked?
It sure sounds like it's blocked. Purchase a venturi tube cleaner (about $5) or try removing it and lightly tap on the ground to try and unplug the little holes that have filled with debris. If you have access to some air tools, try blowing it out-similar to an air filter of a car.
Posted on Jun 24, 2008
I need a users manual for Charmglow 5 burner gas BBQ
Unfortunately, you listed 2 different Brinkmann Charmglow Grills, so I don't know which one you need the manual for. In any event, go to the link below and enter the correct model number for your grill and you can download the Owners Manual.
http://www.brinkmann.net/my_grill.aspx
Hope this helps to get you started.
Mar 07, 2011 | Brinkmann Charmglow Stainless Steel LP...
My turbo built in bbq has 4 burners. what do the
the burners need cleaning remove burners put them clr or clean out burner holes with a paper clip screws are air gas mixture best left as they are
Jun 21, 2010 | Barbeques Galore Turbo STS 4-Burner...
No instructions came with bbq pruchaased today at target
you should be able to google your bbq and find instructions there or the bbq center in calgary
Jun 20, 2010 | Brinkmann Charmglow Stainless Steel LP...
How does one replace charmglow burner tubes on my
most of it yes to get too, the parts you wish to replace
Jun 14, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
PUSH BUTTON IGNITOR DOES NOT LIGHT THE BURNERS
Clean any grease or residue that might be on the ignitor preventing it from sparking.  If it is clean and it does not spark when pressed, replace it.
May 20, 2009 | Grilling
Grilling Logo
441 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
