Question about Garmin Nuvi 610 GPS Receiver
Bluetooth enabling whenever i try to enable the bluetooth to use the handsfree on the nuvi it freezes on the screen 'bluetooth enabling' ive tried backdating the software but this doesnt work and there doesnt seem to be a solution online yet! MY BLUETOOTH IS ENABLING FOR EVER ON MY NUVI 610
  • Anonymous Oct 17, 2008
    I bought a 2009 SX4 wich came with a 7 series nuvi about 3 weeks ago. I used the bluetooth twice and somehow it disabled itself and now I cant re-enable it or add and delete phones.
  • jay3005 Apr 23, 2009
    I HAVE HAD THE SAME PROBLEM WITH THE BLUETOOTH FREEZING ON MY NUVI 610. IT WORKED FOR A WHILE AND THEN STOPPED. IS THE SOLUTION AS DESCRIBED THE ONLY WAY ?
For what its worth I am getting the exact same problem. I understand that Garmin have a fix for this but you have to send/take it to a registered repairers to get the software downloaded. Hope this helps.
Posted on Jul 13, 2008
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How do i pair my 265wt with my LG vx9900?
Garmin claims the nuvi 265wt (et al) supports the LG VX9400, which means it's also likely to support the VX990 (but one can't be certain).
1. From the main screen on the nuvi, touch Tools>Settings>Bluetooth.
2. Select Enabled.
3. On the VX9900, do the equivalent to enable its Bluetooth port.
4. Let your phone search for Bluetooth devices.
5. Select the nuvi from the list.
6. Enter the nuvi Bluetooth PIN (1234) into your phone.
You can do steps 4-6 from the nuvi if your phone is already enabled for Bluetooth.
Jan 17, 2010 | Garmin nuvi 255W GPS Receiver
Bluetooth doesn't reconnect to my Jaguar handsfree
This might solve your problem; go on your blackberry and check in your bluetooth device list for your Jag's handsfree once you've found check the properties of it make sure it says "yes" under the trusted option now if that doesn't work then you need to check in the same properties if "encryption" is enabled if not enable it and you might not have to manully enter it all the time now if it already says enable you could try to disable encryption just to see if that helps. If you have any more questions or more information on this situation just post back and I will gladly help you some more.
Cheers,
Kyle
Jul 08, 2009 | RIM BlackBerry Bold 9000 Smartphone
Freezes bluetooth enabling
Have you tried...
http://reviews.gpsfaq.com/downloads/garminnuvi660manual.pdf
See page 10, which shows you how to reset your nuvi.
Jun 26, 2009 | Garmin Nuvi 610 GPS Receiver
Bluetooth will not enable
This is solved in a related post by silentspoon
http://www.fixya.com/support/t236067-bluetooth_enable
I just tried it for the same problem, worked great
Apr 23, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 760 is stuck on enabling bluetooth
Seems they have been having the identical problem with the 660
Here's a link to the solutions..
http://www.fixya.com/support/t179960-garmin_nuvi_660_bluetooth
The 2 best suggested fixes were probably that you need to reset the garmin ( instructions at link)
Or update the bluetooth software ( Probably the best solution)
Sad that the left hand does not know what the right hand is doing but this is what happens when you have a marketing company in one country having their product made in another... :(
Aug 17, 2008 | Garmin Nuvi 660 GPS Receiver
Enabling Bluetooth locked up
I had the exact same problem, very similar scenario. I seem to have fixed it by...
1. entering maintenance mode (press finger on upper left corner of screen during power up)
2. Press 'View Diagnostics'
3. Page to (Press 'Next' 5 times) Bluetooth Status Page
4. Press 'Updt PR'
5. Wait for 100% progress bar
6. Exit by pressing 'quit', then 'restart'
Good Luck
Feb 06, 2008 | Garmin Nuvi 660 GPS Receiver
I am having the same issue as you are. I am getting frustrated and have been looking every where online, does anyone have aclue in how to fix it.
Dec 08, 2007 | Garmin Nuvi 660 GPS Receiver
Bluetooth enabling
The complete solution - user reset is NOT necessary:
Whenever I purchase a new electronic device, the first thing I do is update the firmware. This has me in a bind in this case.
I updated my Nuvi firmware, then my BT firmware.
A few days later, I got the "Enabling Bluetooth" hang. I followed the advice on this page, but "Bluetooth Firmware Update" would not appear in the webupdate list.
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2. Turn on your Nuvi, press view map, press speed, press and hold the middle of the speedometer (the circle that says 0.0mph in it). After five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7. Connect the Nuvi to your computer. Run the webupdater and if the latest version is already detected on your Nuvi, simply proceed and browse the list of further updates.
8. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR skip to step 10 below, otherwise complete your fix with the next step, step 9.
9. If the "Bluetooth Firmware Update..." (or similar text) appears in your list, select this update and agree to term of service, and have the updater load the firmware onto your device. Unplug your device. It should powerup automatically. Power off. Power back on. Your BT should be back in business. Do NOT continue with the next steps. You are done.
10. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in the list, then you need to remove the offending update that is making WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14. DELETE "006B055301.GCD". This file will be one of two GCD files in the directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date Modified" is the original firmware. The other file is the new firmware that the Nuvi believes is installed. By deleting the newer of the two files, WebUpdater will see that your Nuvi is out-of-date. Return to step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
Sep 01, 2007 | Garmin Nuvi 610 GPS Receiver
Garmin Nuvi 660 - Bluetooth
I fix this problem for my Nuvi 660 Europe. I found resources in Italian language only: 1 - go to http://www.garmin.it 2 - in the search texbotx (i the up left corner of the page) type bluetooth and press enter 3 - click on the 1st faq that will appear 4 - download the file FileBluetooth.zip 5 - unzip the file 6 - copy 006B055301.GCD in X:\Garmin\RemoteSW directory 7 - reboot your nuvi At this poin bluettoth would be ok newly. Bye
Aug 08, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 610 GPS Receiver Logo
246 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
