Question about Whirlpool 24 in. DU1050SS Built-in Dishwasher
Clean light flashes 7 times
Looking for the codes in bottom of dishwash and none are there. Can you tell me what 7 flashes means or direct me to a copy of this code sheet???
  • 3 more comments
  • applfixer Nov 01, 2008
    Very same problem jimmy109 describes.
  • alanandre195 Mar 01, 2009
    I ran my dishwasher at night and woke up to the cleaning light blinking 7 times . I am unable to get my dishwasher to work. My model number is du1050 and little over a year old.
    thanks
    andrea
  • Tundraboys Mar 04, 2009
    I have the same problem. I have a DU1050XTPB3. The clean light continues to flash and won't allow me to restart the dishwasher.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    I can't find anything with the model number you posted this question under. Can you please verify the model number again? It should be located somewhere inside the door opening. If the tech sheet is not located directly behind the bottom panel, sometimes it is placed along one the side walls under the dishwasher. You may have to pull the dishwasher out from the cabinet to see if it may be taped to the exterior of the tub as well.
  • nancy Jun 17, 2013
    The same problem with DU1145XTPB6. Called Whirlpool. They said for repair man to come it would be at least $130 plus parts. May just buy a new dishwasher.
  • 5,911 Answers
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
NOTE: There should be a tech sheet located behind the lower panel under the door that lists all the fault codes and how to troubleshoot them. If you need further assistance, please let me know.
Posted on Jun 23, 2008
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
How to reset control board on kitchenaid dishwasher
Check to see if there is a manual behind the bottom panel. It should tell you what that error code is. It may be the heater is not working or some other issue. You will have to repair the problem before this will stop.
Oct 02, 2014 | KitchenAid Dishwashers
What to if the clean light is flashing and dishwasher will not start
That blinking light is trying to tell you that there is something wrong with your dishwasher. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches.
Jul 06, 2014 | Kenmore 24 in. 15079 Built-in Dishwasher
Clean light flashes and dishwasher will not work
when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The green clean light is flashing. It will not go off even when we press cancel. The wash cycle was not completed. The model # is 665.17283400.
The green clean light means that your dishwasher isn't heating the water. Go to the link below to see how to reset the error code and check for reasons that the error happened.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 05, 2011 | Kenmore Dishwashers
My Whirlpool DU1145XTP won't turn on. Clean light
Check the themistor in the control panel. Radio Shack sells these for about $1.30 each. I replaced the one in my dishwasher three years ago and have had no issues since.
May 16, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
The clean light is flashing 7 times on my kenmore dishwasher and it won't run. What does this mean?
when the light flashes 7 times it is telling you the machine has a problem and the flash is a error code. depending on the model it could me that the heat sensor and circuit board has to be changed. check the make and model #.Go to searspartsdirect.comand you can look up parts also they can ship the parts.
Mar 06, 2010 | Dishwashers
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
GE Profile dishwasher GSD4930X88WW will not start C3 error code
The wiring diagram for GE dishwashers is usually found under the dishwasher, take the bottom panel off, then look for a envelope about 3"x5" up against the bottom side of the floor of the dishwasher, right under/behind the front edge. If its not there it makes servicing it tougher. C3 code means the drain sensor is not functioning, C7 code means the temperature sensor is not functioning.
As to the voltages used, I would only know that by looking at the wiring diagram (which I do not have).
Jan 14, 2008 | GE GSD3800G - Multiple Color Built-in...
Whirlpool 24 in. DU1050SS Built-in Dishwasher Logo
357 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
