Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer
I have a Frigidaire electric clothes dryer (front loading, model LEQ1442ES0) that is just a month shy of 3 years old. All of a sudden, if you just touch the top of it, it turns itself on and beeps twice. This started happening a few days ago and before that it never gave any trouble. The documentation that came with the machine does not cover this situation and I am unsure how to proceed.
I am appreciative of any help.
Josef
  • kndporter Mar 13, 2009
    My Frdgidare model# LEQ1442OS which is only 1 & 1/2 yrs old just started doing the same thing but also not only whne the top is touched but if something like a small laundry soap bottle is on the top. Also it will only heat on the towel cycle. If I used the other cycles the temp light goes automatically to cool down. While it is drying on the towel cycle it randomly beeps throughout the cycle. When the dryer is off sometime the lights turn on by themselves. and it starts beeping. I did some research and thought it was a control board, but I can't find any directions on how to get the top off to swap the boards out. The outlet is fine by the way..... CAN STAND THE BEEPING ANYMORE HELP!!
  • 525 Answers
I was unable to locate a similar complaint through my service database, so this is going to be a hit or a miss answer.
This model has an electronic control board in it and it is possibly picking up a static discharge from your body and powering up the start relay. This may be due to improper grounding or a recent power issue. This type of failure apparently does not happen with a 240 volt appliance often enough to be in the books. I might suggest that you unplug the dryer for 10 minutes, then plug it back in to see if it corrects the problem. If not, you will want to have your outlet inspected by an electrician. You may also have to replace the control board, if the electrician finds the outlet satisfactory. You may also just want to consult a factory authorized servicer that would be capable of checking the outlet AND testing the board before replacing it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 20, 2008
My dryer is ten years old. A few months ago, some of the clothes would come out with rust stains on them. Some of the clothes would get caught in the seams which would cause staining, tearing and...
I would suggest replacing the front drum bearing. Sounds like the gap is now excessive, obviously allowing clothes to get caught up in there. Drum must be removed from the dryer to do this.
Good luck, hope this helps.
Aug 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
Aug 18, 2009 | Frigidaire FEQ1442ES Electric Dryer
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLEQ2152ES Electric Dryer Logo
303 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
