Hi mate, you might want to change your DNS server to google DNS or openDNS. They both are fast, responsive and robust. Do you know how to do it?
1. Open you web router management
2. Under Network > WAN tab, make sure you enable this option and change the primary and secondary DNS server to the ones below, they are google DNS. Save it and reboot. Hope this helps
This error can be fixed and repair within no time and you can do it yourself without the trouble of taking it to the repair shop. All you need is a Easy and Complete Guide to PS3 Repair. This PS3 fix manual would enable you to repair all major PS3 problems and contains lots of diagrams and instructions for your guidance. I hope it would help you save money and time :)
I'm pretty sure that the problem (though the machine indicating otherwise) is that gmail requires SSL, and the Scan to Email (server) doesn't support SSL. If this is the problem, you can easily check it out by trying to use some other mail, with another SMTP server, which doesn't require SSL.
If you are with Vodacom, just dial *111# , select “Device Setup” and follow the instructions.
Name APN Username Password Primary DNS
Vodacom internet None None 196.207.40.165
Secondary DNS 196.43.46.190
1. Try leaving out DNS addresses first. DNS servers are usually assigned automatically to your device on connect. 2. If you are using Vodacom and GPRS does not want to work, first call customer support and make sure your sim is activated for the “internet” APN.
The 80710102 problem is caused by a DNS error, which basically means that your PS3 is trying to navigate the Internet without knowing where it needs to go.
If you follow the link below I have written an in-depth (and free) article about how to fix PS3 DNS errors and get rid of the 80710102 code on your console.
