Question about Lexmark X5470 All-In-One InkJet Printer
Lost lead hi can you tell me where and how much i can buy the mains lead for my printer
  • 550 Answers
The cable you are after is a new standard type, ask at your local pc dealer radioshack the source, for a 'mickey mouse' laptop cable (the end supposedly looks like the mouseclub logo), about $8-10 locally in NS at cablesUnlimited
Posted on Jun 20, 2008
Where can I get a replacement power cord for my Lexmark printer.
Hi
Looking at the setup and spec sheets, the power supply is built in therefore no separate power block (transformer) to worry about. The power cord on the set up sheet looks to be a "Figure 8". Check on the printer itself and if the socket looks like this:
then it almost certainly a standard lead that is used for many electrical appliances as well as computer peripherals, and should be obtainable at most electrical or computer shops. If you ask for a Figure 8 mains cable they should know what you mean but if have a way to take this picture with you - even better !
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 17, 2014 | Lexmark S815 Genesis AllInOne InkJet...
Why does my epson R280 Givers me a Communication Error, what does this mean
It normally means that the signal between the printer and computer had been corrupted or interrupted. Check that your USB cable is not damaged, unplugged or even slightly loose. Unplug and re-aligns in both ends. Use a different USB port on your computer if you can.
Keep the USB lead and printer away from unshielded mains or hi-voltage cables as as they can corrupt data signals. Next reinstall the printer driver. If all this fails, try your printer and lead on a friends computer. If it works, look for the problem in your laptop otherwise maybe it's time to buy an Epson wireless multifunction printer.
Aug 16, 2014 | Epson Stylus Photo R280 Series
Husqvarna designer 1 lost mains lead
Call your local husqvarna sewing machine dealer. If they don't have one they might be able to offer an aftermarket alternative.
Oct 20, 2012 | Husqvarna Designer I
I lost my main cable to woofer so where i can buy the lead from that lead connect woofer to main plz help me
Hi, I've just purchased the same unit from **** smith without the cable for a discounted price, called this number (0288583000) and they sent one out straight away without any questions. All I told them is that I purchased it and it came with no cable. Hope this helps
Apr 28, 2012 | TDK NX-8CD-BKDS
Have moved house and lost power supply lead, where can I get one please
Hi and welcome to fixya,
Easiest to find one is to search on ebay on nearest place to your location. You can find cheap parts there instead of buying a brand new power supply.
Hope this helps,
levibit
PS. What country are you from? So i may find you one.
Jan 18, 2011 | HP PSC 1610 All-In-One InkJet Printer
Hi I have got a Lexmark X1190 printer and
you should have a cord for the power supply that goes into the printer from the power supply it plugs into the supply then into the printer, if you don't have it take it back to where you bought it and tell them it's missing. Hope this helps and thanks for using fix-ya.
Jan 26, 2010 | Lexmark X4650 InkJet Printer
Printer won't turn on...is plugged in and has been printing well.
hi, have you tried checking, changing the fuse in the plug.
check the lead is fitted correct.
as for the fuse is the printer running of mains lead or just of the usb lead let me know, if its mains the unplug the lead that goes to your comp and then try it with just the power lead plugged in to see if that makes the differance.
Check the mains lead works try it on something else if you can if its running off only the usb lead then the lead may be at fault.
Let me know then i can assist you further ok
Nov 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Lexmark x73..want to replace mains lead. wherecan i get one and approx how much
Having a X73 myself, it uses a transformer to reduce the voltage, the output on this transformer is (from memory) around 30 volts DC, about 1.5 amps (1500 milliamps) output. Let me know if your machine had a transformer also, as I am in Australia I do not know what your power requirements are. I can advise as to further details if needed as I believe some OLD HP transformers are/were similar in voltage output. Send e-mail with X73 in heading to kaos_reflex@yahoo.com.au, that way I know you are keenly interested in follow up, I can check further then.
Oct 12, 2008 | Lexmark X73 All-In-One InkJet Printer
Hi i have mislaid my lead that goes into my printer and the electrical supply can you please help and tell me what lead i need to purchase
If lead you mean power supply, I suggest you go to a computer store as they will most likely have a possible match. Most printer power supply leads/cables have a figure 8 female plug on one end and the plug on the other. The other lead/cable is the USB printer cable which you can buy at the computer store. If your printer is small enough bring it to the store to find a good match. If not I suggest you trace the outline of the female plug on the printer and bring it to the store. Hope this helps.
Jul 25, 2008 | Lexmark Office Equipment & Supplies
Mains lead
If this was in the box when buy you can contact Lexmark and get it replaced for free the main chord or if want you can buy the power chord online:
Use this link :
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://support.lexmark.com/cgi-perl/support.cgi&&req=:::-1::
Jun 21, 2008 | Lexmark Z1420 InkJet Photo Printer
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
