SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
SOURCE: the beater bar/brush won't turn
HI THERE,
FIRSTLY, REMOVE SOLEPALTE BY QUARTER TURNING THE 3 COLOURED STUDS,THEN CHECK TO SEE IF THERE IS ANYTHING OBSTRUCTING THE BRUSH BAR OR IF THE BELT IS WORN OR SNAPPED. IF ALL SEEMS WELL PUT THE SOLEPLATE BACK ON AND ENSURE CLUTCH IS ENGAGED TO AUTO AND TRY IT AGAIN. IF NO JOY THEN PLEASE COME BACK TO ME.
REGARDS
DAZ
SOURCE: I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
SOURCE: Dyson Animal 07 beater bar not spinning - belt not broken
if your unit has a clutch it maybe that it is in the off position or the motor belt is broken your unit has to belts if its a clutched model
