Nokia 6125 Cellular Phone Logo
Posted on Mar 22, 2017
Hi i insert a Sim card in NOKIA 6125 cell phone but it give me this message :Start Up Phone without Sim card... 1. Power ON your Nokia 6125 without a SIM card. 2. Compose #PW+CODE+1# where "CODE" is the Unlock CODE you received from UnlockallCellular.com (the Unlock CODE that must be entered will look something like this: #pw+555555555555555+1#). 3. Or try this alternate CODE #PW+CODE+7# (most FIDO-locked and some other Nokia cell phones). 4. You will see a message "SIM Restriction Off". 5. Your Nokia 6125 is now unlocked! i did this steps but i got this message: Can't Undo Restriction I could use this cell phon before, but now it's like this.. How can i solve this problem... Help me please
5 Related Answers
A
Anonymous
  • Posted on Jul 15, 2008
SOURCE: How do I unlock my Nokia 2610 b AT&T Phone
it ask me to put the restriction code
Anonymous
  • 6 Answers
  • Posted on Sep 05, 2008
SOURCE: Nokia 6500 slide - RESTRICTION CODE
Hi, I need your help for getting undo code for the following mobile:
Nokia 6500s-1
V04.81
RM-240
(c) Nokia
Varant:01.06
IMEI: 353076027844417
Language: V 04.81
Service by United Kingdom-3
My contact mail: [email protected]
Anonymous
  • Posted on Sep 18, 2008
SOURCE: nokia 2630
I need an unlocking code too please...
I'm in Latvia
IMEI: 352066028720998
Thanks!
Anonymous
  • Posted on Dec 07, 2008
SOURCE: I need Nokia 6270 Restriction unlock code
Hi
I need Nokia 6270 Restriction unlock code.Can you help me?
Anonymous
  • 32281 Answers
  • Posted on May 02, 2010
SOURCE: what is pw
To display “p” press “*” three times within one second,
To display “w” press “*” four times within one second,
To display “+” press twice “*” within less than a second
Yar sim card rejected
There may be various reasons for it.
1) Your SIM card might be damaged. Check inserting the SIM card in any other active unlocked phone.
2) The SIM port on the cell phone might be damaged. Check inserting any other active SIM card to your phone.
3) The cell phone might be network restricted. Try inserting any other network's active SIM card to it. If the device reject that too, then you need to unlock the phone. You can unlock a Nokia C1-01 safer and easier using unlock code. You can get the accurate unlock code for a Nokia C1-01 from TheUnlockArena.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia C1-01 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C1-01.
3 - Compose #pw+CODE+1#.
4 - The Nokia C1-01 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C1-01 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C1-01
Oct 05, 2014 • Nokia C101
2answers
How can I get the code for restricted phone nokia model 2610 b type:RH87, IMEI :011673004978483 ;thank you
How to enter your Nokia unlocking code
Use the * (Star) Key to get the p w and + characters.
Press * key 3 times for p
Press * key 4 times for w
Press * key 2 times for +
Please note: You only have 3 attempts to enter this unlocking code.
To start with, when you turn your phone on without a SIM card you should see the message 'RESTRICTED'. If you don't see this message, turn the phone off and insert a non-accepted SIM card (ie not locked to) and carry on as normal.
Nokia DCT4 Models (Older phones)
1. Turn on your phone without a SIM Card in it
2. Enter the unlocking code # p w + YOUR_CODE_HERE + 1 #
3. The phone will now unlock.
Note: Use the codes ending with either +1#, +7# or even +5#.
Models : Nokia DCT3 (Oldest)
Note: Use the codes ending with either +1# or +2# only.
1helpful
Nokia n73 offline
Hi first of all after inserting Inserting Sim Card and power on your phone,,a message will prompt you to select "Start up phone without Sim Card" select NO. If there is no any option displays a there might be something wrong with Sim card related components.So try to clean the sim card slot.Otherwise you need to visit mobile repairing shop.Thank you
When i insert my sim card in my nokia 2220 slide the ask me to insert code and my phone is restricted
Hi, If your Nokia 2220 Slide is network restricted, You can unlock it safer and easier using unlock code. You can get the unlock code for a Nokia 2220 Slide from www.simpleunlocking.com/nokia-2220-slide/rs16wp9/ at low cost.
UNLOCKING STEPS FOR NOKIA 2220 SLIDE
1 - Switch on your Nokia 2220 Slide without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2220 Slide.
4 - The Nokia 2220 Slide would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2220 Slide mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 2220 Slide
Oct 10, 2012 • Cell Phones
5helpful
4answers
I have a problem with my Nokia C1
Hi, You can get the restriction code for a Nokia C1-01 from www.onlinegsmunlock.com/nokia-c1-01/rs7wp9/ at affordable cost.
UNLOCKING STEPS FOR NOKIA C1-01
2helpful
2answers
Is unlock my cell phone or unlock contact service
If you need to use another SIM card in the NOKIA 2730 you need to unlock it...You can get the unlock code from the site Prounlocking.com/nokia/rs8wp8/ and unlock it easily.Then use with other GSM Network sim card in it..If it says contact service..You can contact the service provider..To check whether your Phone is a locked or an unlocked phone..You can insert other GSM Network sim card.If it accepts that sim It's an unlocked phone,otherwise it asks for restriction code or enter unlock code,Its a locked phone you need to unlock it.
My sim is rejected how to activate
1. Power down the Nokia cell phone before inserting the SIM card. If the phone is on when you insert the SIM card, it may not detect the newly placed device.
2. Insert a SIM card from your specific wireless provider. If you are attempting to insert the SIM card of a different company, your Nokia phone may not properly detect or use the equipment.
3. Slide the SIM card completely into the SIM card port on your Nokia cell phone. If the card is not pushed in all the way, your phone will not detect the information.
6helpful
My nokia n73 seems offline and say insert sim even i have inserted allready what i should do?
After you have inserted the sim card messages shows"start up phone without sim".Yes Or NO, press NO. If not OK the problem comes from sim IC or Sim case.
2helpful
MY NOKIA 6300 IS SAYING 'NO SIM CARD INSERTED', BUT THE SIM CARD IS INSERTED. WHAT CAN I DO?
no problem.. jus remove your sim card and reinsert it. .sometime it may happen like this..
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
