Question about KitchenAid KERC507 Electric Kitchen Range
Oven Door Hinge is broken Kitchenaid KERC507 range
Where can I get oven door hinges at a reasonable price?
  • Anonymous Mar 22, 2014
    How to change the oven light bulb
  • 1,314 Answers
At about any appliance parts store in you area you just need your model and serial number there are links on this site kitchenaide is made by whirlpool so they can help or if you want to do it online this is good
Posted on Jun 20, 2008
How to remove oven door
hi deirde.
try this or go to the link at the bottom.
To replace oven door(s):
  1. Grasp door at each side.
  2. Align slots in the door with the hinge arms on the range.
  3. Slide the door down onto the hinge arms until the door is completely seated on the hinges.
  4. Push down on the top corners of the door to completely seat door on hinges.
How to remove and replace the oven door - KitchenAid Product Help
How to remove oven door Google Search
Nov 03, 2017 | Ovens
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
How do I take apart a KitchenAid Oven Door, Model Kerc507?
this is Kitchenmaid / Whirlpool oven door disassembling video.
Feb 25, 2012 | KitchenAid KERC507 Electric Kitchen Range
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
I would like to clean the inside of my oven window do I have to take the door off and remove the cover.
yes, you have to take the frame off, to get to the inner part of the glass. many new stove doors can come of by puling the door up, and it will lift of the hinge.
Dec 07, 2008 | KitchenAid KERC507 Electric Kitchen Range
Over window cleaning
you have to take the door apart. by taking the frame of, many of the new oven doors will come out or of the oven by puling on the door up and it will come off the hinge.
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
Broken inner glass on kitchaid range how to remove the door
screws near the hinge, make sure to get oven/tempered glass sometimes the screws are located in the crack between the oven and door on the bottom
Jun 12, 2008 | KitchenAid KGST307 Gas Kitchen Range
RE: f5 fault code; kdrp407hss
Solution!!! The hinges that Kitchen Aid uses are the problem. If the door is opened quickly & bottoms out, the steel in the hinge bends a little. So when you go to close the door it won't close all the way.... which causes problems with the latch , latch switch, oven cleaning, etc.
After taking apart the door several times I realized the hinge can be "fixed" without even removing the door. Follow the directions in the user manual for door removal... after inserting the little metal hinge stops (a drill bit or nail will work) Close the oven door till the stops won't allow it to close any further.....then gently but firmly, push forward. This will bend the hinge back to original shape. Remove the pins...Voila!!!
I wish kitchenaid used hardened steel or a thicker hinge....then this wouldn't happen.
Nov 11, 2007 | KitchenAid KDRP407HSS Dual Fuel (Electric...
KitchenAid KERC507 Electric Kitchen Range Logo
224 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
