Question about Video Game Consoles & Games
I have a slightly damaged gamecube memory card a tiny bit of the green circuit board has been snapped off is there any way to repair it or to retrieve the data on it?
    Problem Solver:
  • 50 Answers
Yes, but the only way to do it would be very hard of an average joe to do. you would have to know how circuit boards worked, and how to soldier.
Posted on Jun 20, 2008
On pokemon XD it keeps saying that the save file currupts I have alot of room on it but it still crrupts so what do I do to fix this
  • Fully Corrupt:
    When the entire save area of the Memory Card becomes corrupt, the system will inform the player that the Memory Card is corrupt and offer to format it. The card must be formatted before gameplay begins or when the game attempts to access the Memory Card. The exact message may vary from software to software.
    Follow the steps for formatting a memory card.
    For specific issues with the Memory Card 1019, please click here.
  • Suggestion: It is always a good idea to copy your most important files to a second Memory Card as a back-up.
  • Data Area Only Corrupt:
    When only the data area of a Memory Card is corrupt (not the entire Memory Card) the game may not detect this until the Memory Card is accessed. Once it is accessed, the game will inform the player that the file being accessed is corrupt and must be erased. The game will only delete the one file being accessed and will not format the entire Memory Card (Other saved game files on the Memory Card may be OK).
    Follow the steps for deleting a file.
  • Memory Card is Damaged:
    If the Memory Card has been physically damaged, or has been damaged beyond repair, you will get this message. The Memory Card will need to be replaced. The system may attempt to format the card, but if it cannot it will give the error Memory Card is Damaged. There is no way to recover the game data from the memory card.
    Please use our convenient repair options.
This procedure is only used if a corrupted Memory Card is inserted into the Nintendo GameCube.
If required, this procedure will begin automatically when you select "Memory Card Screen" from the main menu. You cannot use this procedure to erase files from a useable Memory Card.
  1. After selecting "Memory Card Screen" from the Main Menu, if your Memory Card requires formatting, a window will appear to ask for confirmation for formatting.
  2. Use the Control Stick to select "YES" and press the A Button
  3. A window will appear to notify you that all data will be erased and ask again for confirmation for formatting.
  4. Use the Control Stick to select "YES" and press the A Button.
NOTE: When you format a Memory Card, all data will be permanently erased and unable to be recovered.
Jan 11, 2011 | Nintendo GameCube Console
Tip
Duett Washer Diverter valve not working, F 13 alarm code.
I fixed my Duett diverter valve by unsoldering the tiny switch from the pc ( printed circuit ) board, and replacing it with another similarly sized switch from an electronics store ( Active Electronics). The switch cost less than 30 cents, and after I slightly modified the plastic snap on cover ( the switch I bought was 2 pole instead of the original 1 pole) my washer worked again! ( I did have to sand down the plastic switch button a bit ,as it was longer than the original one).
on Apr 25, 2015 | Vehicle Parts & Accessories
When I try to save replay,s on the gamecube game: tony hawks pro skater 3 I have a problem, First i play, then i save a replay,Then i go to main menu, options, load replay, i see a list of all my...
Memory Card Error Messages
Fully Corrupt:
For information on locating replacements for older products, please click here.
Dec 12, 2010 | Nintendo GameCube Console
My micro sd memory has snapped at the teeth and t memory card is quite badly damaged do i have any chance of recovering my photos?
There are some digital photo recovery companies that can retrieve your pics. Depending on how many pics are on the card and how badly damaged it is, they charge between $100 to $500 dollars.
Oct 01, 2010 | Cameras
Hi. Last time I went to used my camera the screen showed a message saying the memory card was damaged. When I tok it out I saw that it was slightly damaged on the bottom strip. I have replaced it with...
It is possible that there are bits of the damaged pieces struck inside the card reader contacts in the camera.
So if you can remove the battery and memory card and tap upside down ,you might be able to retrieve the broken pieces.
use a fine jett of air to spill out the dirt and try. if not repeat the procedure.
If there is still the issue you may have to open to get access to the slot to clean or rectify a damaged contact.
Sep 24, 2010 | Nikon D40x Digital Camera
The usb port seems to have broken
The USB jacks should just be soldered to the motheboard. How comfortable are you with using a soldering iron on a multi-layer printed circuit board that can easily be damaged if a bit too much heat or a bit too much force is applied while removing the old sockets or putting in the new ones. There is also the matter of first finding identical replacement USB jacks. You could also pay a PC repair shop to do the repair for you.
If you have an open memory card slot on the laptop, a USB adapter card like one of these may work out for you:
http://www.newegg.com/Product/Produc...82E16815123021
Just be sure you properly identify the memory/expansion slot type on the laptop and get a matching USB adapter card.
Pleaes post your feedback and Vote if the problem resolved as per your satisfaction.
May 25, 2010 | M-Audio MIDI Controller Keyboard
Games arent starting
Possibility #1:
The disk reader of the game cube is damaged
Possibility #2:
The disks are damaged
Dec 07, 2008 | Nintendo GameCube Console
Want to travel to towns
If you are trying to transfer the gamecubes's memory card into the wii, that will not work; you will either have to get another game for the wii (and or gamecube) or have another memory card to go to another town.
Nov 25, 2008 | Nintendo Animal Crossing for GameCube
Game cube
read my previous post to you and try that and let me know if it worked or not sounds like you will have to follow those instructions. maybe it will work. since the gamecube states the card was damaged so a format will be required so the method will wipe it clean and cross your fingers and hope it works.
Oct 03, 2008 | Nintendo GameCube Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
