Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60pp92902/17f television convergence issue
Tv picture looks 3d. check convergence. all is well but the multipoint red convergence has many points that I can't get to converge. the large center screen cross hairs line up but many around the outer edges won't align and the lines are actually bent. Is there a fix I can do myself. need to know what parts where to get them and instructions please. thanks
  • Paulsil Jun 22, 2008
    where are the convergence ic's located in my philips 60ppo920217 projection tv. I would like to proceed with the repair.
    Master:
  • 638 Answers
Check out the bulged up capacitors on the main board if there is any replace it.it is also possible that some ICs get overheated n stops responding.
for all detailed information n step by step troubleshooting link is given below:
http://www.ptdoityourself.net/tl/tl_index1.html#8ab
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 22, 2008
    Genius:
  • 1,142 Answers
The convergence ICs need to be replaced there are two of them
Posted on Jun 20, 2008
  • 796 Answers
Actually your vertical display ic is faulty....you need to replace them
  • isaac johny
    isaac johny Jun 20, 2008
    Replace the convergence IC and
    check power resistor for leakage, if values are not exact replace
    them. Once the parts are in place perform the alignment.
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
My philips 46pp9302 picture looks green ive lined up the blue and red colors but dont know whats wrong.....help
The tv have a problems known as a convergence problems,it dead.The tv color lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Oct 27, 2010 | Philips 46PP9302 46" Rear Projection...
The color is way off on the tv. It also looks curved, like if there are words on the tv they go up at an angle toward the edges of the tv. When you try to align the color on the tv you can get the center...
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 01, 2010 | Philips 60PP9202 60" Rear Projection...
Philips rear proj tv multipoint help
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 01, 2009 | Philips 51PP9303H Rear Projection...
Philips nr.43pp7445/69
I don't understand you language but I think you need both convergence amplifier IC's replaced. I hope this helps.
Aug 17, 2008 | Philips 60P8341 60" Rear Projection...
Philips 55PW9363 looks 3d
You need to replace both convergence ICs they are STK392-120 this is an easy repair that you can do yourself and save yourself around 400.00 for about 45 minutes work. You can order the new ICs at the following link and they provide free installation instructions with pictures and also free online support with a support tech while you do the repair. I am one of their support techs. You would also want to order at least 4 convergence resistors and they send the proper ones for your model as often a couple resistors go. Your model uses 6.8ohm 2watt 5% metal film resistors. So to recap you will need (2) STK392-120 Convergence ICs and (4) Convergence ICs . very inexspensive repair if you do it yourself. here is the link.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 60 rear projection hdtv looks 3D
If your red convergence controls will not remove the red in all four directions, you have a faulty convergence IC. You will need to replace both. They cost around ten dollars each. Let me know if you need anything further.
Feb 02, 2008 | Televison & Video
Blue Multipoint converge failure Philips 55PP9753
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2008 | Philips 55PP9753 55" Rear Projection...
PHILIPS 50P8341 60 IN.
Check the other posts for convergence problems. This may be what you're experiencing. Have you tried bringing it in with multipoint convergence? It's under Menu -> Picture -> Manual Converge -> Multipoint Red and Multipoint Blue.
Dec 07, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
