Question about Frigidaire FRS266ZDSB Side by Side Refrigerator
PLHS267ZAB6 Frigidaire Refrigerator
I was being helped with my refridgerator being too cold and It was diagnosed as needing a new thermostat. I have searched for the Part and there is 2 temperature control parts 1 is around $38.00 and the other one
is around $92.00. it does not tell me which one is to control the thermostat.
Can you please help.
pretsos@sbcglobal.net
  • 1 more comment
  • Anonymous Jan 18, 2009
    I also have a Fridgidaire side by side (Model # FRS26W2AW5) that is way too cold. I ordered a new thermostat (Part # AP2132718) for $105.00, but have no idea how to install it. If anyone can give me step by step information on how to install this, I would appreciate it. Thanks!
    I also have a Fridgidaire Side by Side (Model # FRS26W2AW5) that is way too cold. I ordered a new thermostat (Part # AP2132718) for $105.00, but I have no idea how to install it. I would appreciate it if you could give me step-by-step instructions on how to replace the thermostat.
    Thanks!
  • flyingtarzan May 11, 2010
    is your freezer to cold ? lets slow down,
    Problem Solver:
  • 8 Answers
Hello Guest...the easiest way to see how the thermostat is installed is to get the parts diagram from Frigidaire, using the model number. It shows you how the control panel is put together. Holler back if you can't figure it out. Just trying to help! :)
Posted on Feb 20, 2009
2 Suggested Answers
refritech08
  • 149 Answers
SOURCE: PLHS267ZAB6 Frigidaire Refrigerator
theres one for the freezer and one for the refrigerator what seems to be the problem so i could pinpoint which one to change
Posted on Jun 21, 2008
Frigidaire problems
Use the link below to view and read the user manual. If this is a used refrigerator it is possible that there may be a problem but it should be minor. The refrigerator section is cooled by air from the freezer. This problem is usually caused be excessive frost but you should not have frost buildup in only 24 hours.
There is also parts lists and diagrams.on the site.
I am also including a link to youtube videos about refrigerator problems.
FGHT1832PF0 FRIGIDAIRE REFRIGERATOR Manual
Frigidaire FGHT1832PF freezer cold refrigerator warm YouTube
Sep 04, 2014 | Frigidaire FGHT1832PF Gallery Series...
DA59-00314A
perhaps a low refridgerent situation, call for service
Mar 08, 2013 | Samsung RS2630SH Side by Side Refrigerator
Refridgerator side is not cooling and freezer is wroking fine
1st i must get you to look for some symptoms look on back wall (inside) of freezer. Is there "sno-cone" type frost? yes? defrost problem. heater,defrost thermostat or defrost timer or adaptive defrost control. no? is fan running? is evaporator coil cold ,frosty? no fan but cold frosty coil(that's frosty but not frosted up) then bad fan motor probably. you need volt meter,and know how to use it. otherwise call a tek.
Sep 25, 2012 | Frigidaire FRS3R5EMB Side by Side...
Ice building up on back walls of freezer refridgerator seems then not cold enough or bottom drawer freezing produce
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Frigidaire Refrigerators
The refiridgerator is freezing everything, The coils have been cleaned as well as the filters and no matter the "cold" setting, anything put into the refridgerator is frozen.
It might actually be a bad thermostat, or a stuck damper. All the cold are is "produced" in the freezer section, and there are ducts with dampers that lead into the refrigerator section. If these dampers collect some ice on them it will cause them to stick in there current position. If this is the case, and the dampers are open, then it will always be to cold in the refrigerator. Hope this helps
May 11, 2010 | Frigidaire FRS23KF7AB Side by Side...
My refridgerator will not get cold
Mine was a bad defrost thermostat. Everyone that has a newer Frigidaire has the same problem. Easiest non-professional fix.
Sep 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Jan 20, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
Dec 15, 2008 | Frigidaire FRS266ZDSB Side by Side...
Jun 20, 2008 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire FRS266ZDSB Side by Side Refrigerator Logo
805 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
