Question about Acer AL1716 17" LCD Monitor
Flickers and shows acer logo blue screen sever error
I can't get past the blue screen so i unplugged it and i am using a older monitor now.. My warranty on my Acer is up in 10 days.. i hope everything is free to fix it, i bought it at staples
  • Acer Master
  • 13,433 Answers
If the warranty will end in 10 days contact your dealer right now or acer. repairs are free if the problem is covered by warranty. (for example not abused)
let me know if you have any other questions.
Posted on Jun 20, 2008
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Blue screen error acer desk top
hi friend the blue screen comes when there is a 1:hardware problem
2:virus problem
3:Installation Disk is corrupted
4:RAM problem
First, check your CD and clean or replace it as necessary. Your next step should be to test your system memory for errors with a diagnostic program.
To do this obtain the Windows Memory Diagnostic or Memtest memory diagnostic programs on floppy or CD we mentioned earlier, and use it to boot your system and test the memory. If either of these programs shows any errors in your memory, you have likely found the source of your troubles.
Chances are you will need to purchase new memory. For more information on faulty memory and memory diagnostics, see PCstats Guide to diagnosing bad memory .
Mar 31, 2010 | Acer Aspire™ T180 PC Desktop
I unplugged my Acer al1914 monitor from my computer and plugged a different acer al1914 in my computer and now when I transfer the screen from notebook to monitor it has a blue tint on the entire screen. I...
Check the color settings in the on-screen menu. You can choose between "Warm", "Cool" and "User". Maybe you used the "Warm" setting before and somehow it got changed to "Cool".
If this is not the case, you can try the "User" mode and reduce the intensity of the blue channel.
If even black areas show a blue tint, maybe running an auto configuration from the menu helps.
As a last resort, use the "Reset" menu item which resets all settings to factory defaults.
Mar 30, 2010 | Acer AL1914 19" LCD Monitor
Toggle Between Laptop and Monitor
Fn + F5 toggles the display output, the trick here to wait each time you hit this combination because it goes through several options. Hit it once and it may want to go to just the external, then both the laptop screen and the external. etc. Now Fn + F6 turns the backlight bulb off on the internal monitor to save energy. Now I am giving up the link to your service manual, it is in PDF format so you can make a copy for yourself and keep on the laptop, print it or save it to a flash so you can reference it later. I believe if you take the keyboard off and disconnect the video lead on the left side where the display plugs into the motherboard, then when you power the laptop back up it will default to the external cord and you can use the laptop without any switching. That is what I am doing with an Aspire 5920 that I am rebuilding. Good luck, ParrotHead PC Repair
Just copy and paste the link below to you internet address bar and hit enter.
Sep 05, 2009 | Acer Aspire 3680 Laptop
Monitor problem
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1716 monitor flickers
i Have the same problem, this screen is used on the spare computer we have in a loft conversion and the room does get rather cold, Warming the screen up with a fan heater for a couple of minutes gets rid of the problem. When the fault occurs the buttons on the front to adjust the picture quality don't work they just turn off the monitor.
Dec 08, 2007 | Acer AL1716 17" LCD Monitor
Perform a system recovery:
2 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Alt/F10 during boot right after Acer splash screeen on startup
Oct 26, 2007 | Acer AL1716 17" LCD Monitor
Acer AL1716 17" LCD Monitor Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
