How do i fix error code C00D11B1 Media player 11 ?
  • 520 Answers
Recognizing and Fixing Media Player Error Code c00d11b1
For the majority of Windows Media Player users who encounter the Media Player Error code c00d11b1 message, the problem only begins after they upgraded to 11. In other words, media player versions 9 and 10 worked perfectly well for them.
So, one option is to 'roll back' the player to a previous model that did not encounter any such problems.
To do this, initially go to Start, then Control Panel, and Add/Remove Programs. Next, click on the Windows Media Player 11 icon and click Uninstall.
It will ask if this is really the option you want to take. Confirm that it is, and then be patient as it may take several minutes for the operation to be completed. During this time, it may appear as if your PC has switched itself off, but it has simply deactivated all unnecessary extraneous computer operations, in order to retain memory and processing power for the job in hand.
Next, according to Microsoft, when this particular error code is encountered when trying to stream online video or audio, it most commonly indicates that the proxy settings for Windows Media Player are incorrectly configured.
This can be checked from the Tools menu within Media Player itself, after whch you need to click on Options. Then you must click the Network tab and in the Streaming proxy settings area, you need to verify your settings. If you're not sure what the correct settings are, first, click on Configure, and then in the Configure Protocol dialog box, select Autodetect proxy settings.
In some cases, you can also apparently encounter this problem if Media Player tries to receive an online stream by using the User Datagram Protocol (UDP), but for some reason, it cannot do so.
You may be able to fix this particular error by turning off this UDP option in the Player.
If these solutions are not effective, your problem may be something as simple as Media Player trying to access the wrong audio or video device on your machine.
Open Tools, select Options, and then select Devices. When this comes up, make sure that the correct audio for your PC is checked, and this could very well make your problem disappear.
If none of these operations is effective, then you may well need to check the underlying registry of your Windows operating system for defects and errors that may be causing Media Player to malfunction.
Almost inevitably you will find errors and defects in your registry whenever you run a thorough scan, and whilst it may not necessarily be possible to isolate a specific problem that is causing Media Player to malfunction, the cumulative effect could be the root cause of your difficulties.
If, therefore, you already have software installed on your machine that can scan and fix your registry for you, then you should use it.
If not, you can still avail yourself of a free online registry scan using proprietary software such as SpeedyPC. Whilst you will not be able to repair your registry errors without downloading and installing the full version of the software, nevertheless, the scan will indicate the extent of the problems that you have, and these problems may be what is causing you difficulties with Media Player.
Or download this software after downloading, install this software and try vlc media player. This will install (codec) compressor/decompressor for audio and video more supported multimedia.
Posted on Nov 18, 2010
    New Friend:
  • 109 Answers
See also...
http://www.pc-error-repair.org/pc-code-errors/media-player-c00d11b1/
After a lot of searching on the net i have managed to find a solution to this
annoying error code C00D11B1 For those that have downloaded the wmp 11
update to find wmp does not work ,depending on what sound card you are using
,mine is realtech high def audio .
You need to open control panel , click on sound, in the playback menu click
your device that is showing in my case realtech high def which will
highlight properties, click on properties which intern will show three
headings , General, Levels, Advanced. click advanced and last of all click
restore defaults which will fix the player
Im guessing that this solution could possibly help other users with this
code prob good luck to you if it does
SOURCE:
Windows media player error - "not installed properly and must be reinstalled. Do you want to intall the player from the Microsoft Website?" Media player 11 with Windows XP sp3
you will not be able to upgrade window media only goes to 10 for windows xp. if you are having problems with playback then there are video and audio code packs for windows media that are updated and free.
May 29, 2017 | Microsoft Audio Players & Recorders
Windows Media Player C00D11B1 Windows Media Player can't play the file
Windows Media Player and other media players all have their limitations on what format they can handle.
I suggest you download and try other free media players such as the excellent Open Source VLC Media Player:
www.videolan.org/vlc/download-windows.html
Good luck and have fun!
ps. You should specify what type of media you are trying to play!
Sep 23, 2011 | Computers & Internet
How to solve error message C00D11B1
Computer program errors are discussable. First, the programs require compatibility to the entire computer system to take effects either as downloads or installation from internet of disk drives. Computer software programs have compatibility versions to each system innovated. For example, windows media player version 9 or earlier is installable on older computers where version 10 above compatible to recent innovated computers. In situations that computer least captures the window media player effect requires acquiring another media player. For example, real one media player has the compatibilities to generic device either Microsoft of apple Mac computers. Also, available are generic media programs that least requires compatibilities to install however least has satisfactory expectations discussable. Error observations are solvable either as attaining an alternate program software least incompatible or capturing a computer that is compatible to the program requesting installation.
Feb 28, 2011 | Microsoft Windows Media Player
Encountered error message C00D11B1 while using Windows Media Player
There are different solutions on your problem here I did find some of them:
Try to use ccleaner and be sure that windows media player is checked :
http://www.ccleaner.com/
1: try to download this codek pack and install it :
http://www.free-codecs.com/download/XP_Codec_Pack.htm
2: it is related to updates your error you have to do this :
http://drmlicense.one.microsoft.com/Indivsite/en/indivit.asp
3: try to remove all the files from this folder- C:\Documents and Settings\All Users\DRM\- to a new subfolder and try this :
moving ALL the files in the folder: C:\ProgramData\Microsoft\Windows\DRM\ as well as the files in the “Cache” folder beneath that was the magic trick. I don’t know if you need to move from both folders, . Note that media player had to re-download the licenses. If it not work you can always return them from the folder back.
For more solutions please see here from the source link :
http://strom.wordpress.com/2007/04/06/windows-media-player-error-c00d11b1-solved/
Hope that helps
IF NOT then return here
Please rate my answer
Other support places :
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/default.aspx
Oct 07, 2009 | Computers & Internet
I've lost all sound in my HP Laptop after installing Vista SP2. I checked audio device drivers, made sure that nothing was muted, no luck. I also get an error message C00D11B1 when I try to play CD's or...
Go to the hp website download the latest drivers, un-install the present one and reboot the computer .Windows will on reboot find new hardware and prompt you for the drivers for the sound card.
Good luck
Sep 25, 2009 | HP Pavilion dv4000 Notebook
You've encountered error message C00D11B1 while using Windows Media Player
What Version of Windows Media Player do you have? If you have an older version, I would recommend upgrading to the newest version to see if this overwrites the existing problem..
May 14, 2009 | HP Compaq Presario V2000 Notebook
WMP error message-C00D11B1
Can you try this:
  • Start-> Control Panel->Hardware and Sound
  • Sound / Manage Audio Devices
  • Highlight your audio device
  • Properties
  • Advanced
  • In the Exclusive Media section, UNCHECK the box "Allow applications to take exclusive control of this device."
  • Apply
Hope this helps.
Thanks.
Mar 08, 2009 | Microsoft Windows Vista Ultimate Edition
Error message C00D11B1 comes up when playing video with microsoft media player, please help
Have you tried reinstalling the program?
http://www.microsoft.com/windows/windowsmedia/default.mspx
Choose Media player and let me know if you have the same problem again?
Aug 15, 2008 | Computers & Internet
Files will not transfer to PC or play when attached to PC
Hi have you installed the correct software for your device
Dec 06, 2007 | Olympus WS-100 Digital Voice Recorder
Open Questions:
Computers & Internet Logo
949 people viewed this question
Ekse
Alun Cox
