Question about NetGear Computers & Internet
New ;laptop hi this is a new laptop have netgear router but to enable me to go online have had to put yellow lead from router to laptop how do i get online without the yellow lead
  • 85 Answers
You mean you want wireless internet? You need a wireless router, then you need to go into the setup to set it up @
Posted on Jun 20, 2008
Cant get full online with ps3
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jun 17, 2010 | NetGear WGR614 Wireless Router
I have a netgear rangemax due wireless n router. I had a friend, who is good with computers, set it up for me last april. he set it up through my desktop, which is connected directly to my broadband,...
These are some reasons why your new Hp laptop can't connect through your Netgear Router is because your Router has a security that used a password to connect to your router or the ip address of your desktop and Dell laptop is already setup to the router to work with internet.
You can learn how to setup your router easily.
Smart Wizard:
Netgear Data Sheet:
Here's the instruction how to access your Netgear Router (to change the settings and to allow your new Hp laptop to connect to the internet)
I suggest to use a password security, for easy connection of your computers
Jan 18, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Network wont show up on any Wireless Network List
Reset your router to factory defaults.
For that press RESET button for 10 seconds it is in back panel of router.
hen connect your router to computer with ethernet cable.
Then you can access it with following link.
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Then save settings and restart router.
Let me know if you need further assistance.
Nov 10, 2009 | NetGear WGR614 Wireless Router
I bought a new wireless laptop and want to connect to my netgear router
Is your netgear router already working ?
Is there any other computer able to go online using the same router ?
If there is any other computer online then you don't need to change the settings of the router.
You need to connect to the wireless network.
Click Here for step by step solution
Oct 31, 2009 | NetGear IEEE 802.11b/g - Wireless Router...
Wireless not working
Make sure the wireless pickup for the laptop, integrated or separate is installed properly and is enabled. The laptop should have a function key (check your manual) like "FN". Pressing this key and usually a function key (F1-F12) should tell you if the wireless function if built in is enabled. If the wireless pickup is USB or a PCMCIA, check the installation again and make sure the hardware is compatible with each other. It's usually not a good idea to mix vendors like using a Linksys router with a Netgear pickup.
Aug 23, 2009 | Belinea Computers & Internet
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Connection with netgear to laptop
Helen, you should be able to connect from your laptop to your router wirelessly. From what I understood your router is hooked up to your PC directly. If that's the case from your PC connect to your router and enable wireless. Go to Netgear support web page to find out how to do it. Once enabled, you should see your router's name in the list of available wireless networks on your laptop
Feb 07, 2009 | NetGear DG834 Router
Will not connect to internet
Hi leapam31,
What your router is asking for is a secure wep login. You can provide your partner this number by loging into your router, and go to the securty section of the menu, and generate a new wep key. It will then generate a key, that you should right down, because this new key may block out the existing two computers that already have access. When you log into the router on those machine, you may need to put the same key in.
Good Luck
Jan 06, 2009 | NetGear WGT624 Wireless Router
How do I set a new address in the 850 motorola router
First, you ned to login into your router (check the manuals for this, Netgear has this printed behind the router near Serial no. etc).
Enable DHCP settings, allocate IP-address range say to (enough for 5 computers connecting via this router). Next, configure each computer to accept new IP-address from router by enabling DHCP.
The settings on a Windows XP Professional Desktop:
Need administrator access to your desktop, right-click on Network icon, Internet Protocol TCP/IP Properties, click on Properties button, then select Advanced properties, you can set DHCP from here.
Dec 17, 2008 | Arris Wireless G Broadband Router (wr850g)
Connecting two laptops using Netgear 834G
If its just a router and not a modem router, go into the routers settings and make sure DHCP is enabled to give each pc an automatic IP address and ensure wireless is enabled if using wireless adapters. Next go to the properties of your network card and on the TCP/IP select properties and ensure obtain IP address automatically is ticked. You must also set up using the XP network wizard and ensure file and printer sharing is set up through both pc's.
Feb 07, 2007 | NetGear DG834G Router
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
