Question about Whirlpool Refrigerators
Hello, I have a Kenmore Model 106.56536401 side by side fridge that won't make ice. The water dispenses fine. Thanks for the help
  • 796 Answers
There is an identification tag *right on the appliance* with the model and serial numbers on it. You can find tips for locating the page on your appliances at the following link:
LINK > Model Number Tag Search (http://www.appliance411.com/parts/tagsearch.cgi)
Next might be making sure the icemaker side of the water fill valve on the back of the fridge is getting power when the icemaker should be filling and/or whether the icemaker side of the valve works when powered might be next.
You can read about the water fill valves used on appliances at the following link:
LINK > Appliance Water Fill Valve Information (http://www.appliance411.com/data.php?info=water+valve)
Posted on Jun 20, 2008
    Genius:
  • 1,142 Answers
Check for the thermostat
  • Maanita Chadha
    Maanita Chadha Jun 20, 2008
    It's not coolIf the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
    First, answer these questions:
    • Is the refrigerator completely dead? If so, see “It's stopped completely.”
    • Is the thermostat knob turned to the proper setting? If not, reset it.
    Next, see if the compressor motor is running
    The
    compressor is a football-sized case with no apparent moving parts. It's
    on the outside of the refrigerator at the back near the bottom. If it
    is humming or making a continuous noise and your refrigerator is still
    not cooling, there may be a more serious problem with one or more of
    several different components, we recommend contacting a qualified
    appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Maanita Chadha
    Refer to : www.repairclinic.com
    Water won't dispense
    The part of the=> 2188542 Water Inlet Valve may be defective while you may be getting ice from the ice maker side of the=> 2188542 Water Inlet Valve Let me know iof you have questions, Thanks Sea Breeze Questioins?38124827-761f-4fe9-a92b-e27c07b1020b.jpg
    Jan 06, 2014 | Kenmore 57029 Side by Side Refrigerator
    Water is leaking from our water dispenser. A large amount. An 8 oz cup fills up within an hour. It is coming from the water dispenser on the outside of the fridge. The ice maker is working fine but the...
    Your water valve on the back of the refrigerator is plugged up, there are two sides to it, one side is for ice maker the other is for chilled water dispenser.You may be able to clean it out, if not then you will have to buy a new valve.Hope this helped.
    May 29, 2011 | Kenmore Refrigerators
    Kenmore refrigerator side by side model 25358682890 cold water dispenser does not work. ice maker works.
    Your fridge has a dual solenoid water valve - one side controls the water flow to the dispenser, the other to the ice maker. It's possible that one side burned out while the other is still good.
    Here's a photo of what it looks like:
    Here's a link to the replacement part:
    http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/218658000/0046/253/Model-25358682890/0582/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=25358682890&subCompDesc=Icemaker&brandDesc=KENMORE&modelDesc=Side-by-Side&blt=11
    Before replacing the part, make sure the solenoid is in fact, bad. Get a voltmeter, and touch the probes to the electrical contacts on the solenoid, like so:
    If the meter barely moves, the solenoid is bad.
    If both solenoids test out OK, the other possibility is that the water supply line is kinked or clogged. Also, if your water dispenser has a filter (also on the back of the fridge), it might be clogged. My money's on the solenoid, though.
    Good luck, and if this helps, please my answer!
    Also, thanks to Zenzoidman for the pics.
    Jan 31, 2011 | Kenmore Side by Side Refrigerator
    Kenmore Side by Side not making ice
    This problem is most likely the water control valve on rear of refrigerator. If your ice maker is empty pour tap water inside it and let it freeze. If it dumps the ice then the water control valve. If nothing happens the the thermostat inside the ice maker is defective. Thanks, Sea Breeze
    Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
    Water not going into icemaker. Water dispenser works fine.
    Check the water valve at the back of the fridge if present.
    Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
    Disconnect water lines from icemaker, and blow with compressor if the above did not work.
    May 20, 2009 | Kenmore Refrigerators
    Maytag side by side fridge water dispenser not working
    there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
    Apr 09, 2009 | Maytag MFI2568AE Side by Side French Door...
    I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
    Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
    Thanks, Sea Breeze
    Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
    Water leak From Back Of Fridge
    hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
    Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
    Amana Side by side refridgerator Model SBD20TPE P1190006WE
    hi
    one question : are the units under warranty ?
    if not its pretty easy to swap the dispenser paddles and the membranes
    infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
    thanks
    May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
    Kenmore Refrigerator stopped dispensing water
    Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
    Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Refrigerators Logo
    141 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
