Question about Sony Cyber-Shot DSC-P92 Digital Camera
Memory stick error
Y start my camera and on the screen apear Memory stick error..what can do?
  • 1 more comment
  • ombladon90 Jun 20, 2008
    camera is Cyber-shot 1,3 megapixels dsc-p30
  • Anonymous Oct 24, 2008
    says to reinsert memory stick especially when the relative hunmity is very low. Is there a fix? I have already changed batteries and sticks.
  • bags61 Nov 06, 2008
    1. the camera shows no memory stick. The stick works in other cybershot cameras and other memory sticks don't work either. The camera is not recognizing any memory stick
I had to get a new memory stick when my camera did this...
Posted on Aug 17, 2008
Cannot get my memory stick to work in my camera. The only memory I have is the 'internal memory' which is good for about one minute and possibly 10 photos. How do I get the memory stick of 1GB to start...
Did you formatted memory stick in camera?
Insert memory stick in camera and Format it by going into setup menu, you will see Format option and this will solve the issue.
If problem still not solved and camera gives memory stick error then try another memory stick in camera, you can use up to 2GB memory stick in this camera.
Thanks.
Oct 24, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Memory stick error
Did you format the stick using the camera
if not then try that there seems to be a
problem when formatting with reader
Nov 19, 2007 | Sony Cyber-Shot DSC-F505 Digital Camera
How do i resolve the C:13:01 error on a SONY DSC-W150, "error formatting memory stick" appears on the screen"?
how do you formate memory stick if the camera woke work at all. It keeps saying reinsert memory stick . Must be a w150 problem cause that's what mine is doing too! :(
Apr 21, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
I have had my camera for about 4-5 years. It has worked great. lately it has started to act weird. when I turn it on the screen says access and wont let me take a picture. then after a few minutes the...
Go to camera Menu and select Initialize, OK.
Camera will turn on itself, if problem still exist, tap camera gently and turn On again to solve lens access problem.
Memory stick error can be solved by formatting it through Format menu in camera. Use another memory stick in camera to make sure that camera is OK.
Aug 12, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
When I switch camera on it makes a buzzing noise and says on screen 'camara error number E45'
try to remove the memory of your camera and din insert again or try to replace other memory when the error e 45 dosn't apear it main the memory is your problem buy the new memory or try to format all files to your memory
Jul 04, 2009 | Kodak EasyShare V570 Digital Camera
Sony memory stick pro duo format error
Use this memory stick in other Sony camera to confirm it. Problem still exist means memory stick is bad/ internal breakage.
Jun 12, 2008 | Sony Cyber-Shot DSC-S75 Digital Camera
Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Nov 05, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
Oct 22, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Memory stick error
Try using another memory stick, or insert a confirmed good memory stick, if OK, the memory stick is defective, if the same error, try pressing reset at the back of camera, a small hole beside the the DC jack. if OK, then fine, if still the same, camera needs repair. thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cyber-Shot DSC-P92 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
