Question about Cameras
Failed to bind the socket, error #1907070172 - Cameras
  • 1 more comment
  • Anonymous Jun 30, 2008
    install given software, web cam fail to work. error massage is Fail to bind the socket, error #1907070172
  • dai_kerr Jul 14, 2008
  • lee_wenfu87 Sep 15, 2008
, error #1907070172
Posted on Oct 02, 2008
Print ticket provider failed to bind to printer
Do you have other peripheral hardware connected? ie. a printer?
If so, try to disconnect it.
Win32 Error:
when one process tries to access a file that is currently being used by another process.
Apr 22, 2014 | Dymo LabelWriter 450 Turbo USB Label...
Memory march a text error code 2000-0123 msg memory intergrity text failed
Memory module (or modules) may have failed.
But worth checking that they are seated in the sockets correctly.
(Clean dust and fluff from M/B first)
Feb 04, 2014 | Dell Optiplex 380 Mini Tower Brand Intel...
What does "socket error" mean when I have a "login failure"
It means the recording industry is coming at ya!!! Just kidding.
Apr 18, 2012 | Dell Computers & Internet
A friend of mine fails to bind her with my phone because there is the problem of passkey
If you are binding the phones via bluetooth, just enter a passkey of 1234 and then you will have to enter the same passcode.... The phones should bind together after that.
Thanks
For using FixYa
asnowman
Feb 06, 2011 | Cell Phones
Error code 004 - 361
One of the drum motors has failed or the IOT board.
Oct 06, 2010 | Xerox DocuColor 3535 Copier
Arc 270 error code l404
That is a problem with the black motor, May have a bound up dev housing or drum unit. It is unlikely the motor has failed. But something is binding in your black imaging area.
Aug 02, 2010 | Sharp AR-C270 Color Copier
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Dec 16, 2009 | Sharp AR-M455N Copier
Lens error 12 and 22!!!
The movement of the lens is motor driven. When you turn the camera on, the lens moves. The error 12, error 14, and error 22 refer to control stages in the lens movement ( I think error 22 means the lens won't retract). The lens housing and gear mechanism in this camera is plastic. If there is dust, sand, or debris around the lens housing, it may bind the lens when it trys to extend or retract. By banging it, you might work the gears loose or dislodge whatever is binding the lens (same with the "canned air" blowing out the dust). We've purchased a bunch of these cameras for our electricians in the field. Several have come back with this problem. I've taken the case off, and torn the lens assembly apart, only to find the plastic gears have been "buggered up". It's an inexpensive camera. Try to clean around the lens, give it a few slaps, push/pull the lens.... but failing this fix, buy a new one. Good Luck!
Jun 19, 2009 | Kodak EasyShare C330 Digital Camera
C1 error code
CL code stands for overloaded motor. Motor is drawing to many amps and cuts out. I suspect a failing motor or something binding that causes the motor to draw to many amps. Don't know how to fix it.
Aug 20, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
XEROX WORKCENTRE XL 2120 ERROR CODE L4
L4 can be 3 things. If your lucky, look and see if the lamp is moving properly. Something may just be catching it.
If not, then either the laser or the main board have failed.
Remove the glass first and see if you can slide the lamp carriage without binding or hitching.
Jul 09, 2008 | Xerox Office Equipment & Supplies
Cameras Logo
115 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
