Question about Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive
Cd-rom drive when u put a disc in the light lights up starts to spin for about 10 secs then stops ..can keep doing that does the thing ..cleaned it still nothing ,can u point in the right direction plz? thank you dale
  • ALONE08
    ALONE08 Jun 24, 2008
    ..thank-you for u help ..kinda thought that was it..tried many diff , cd's ...thanks dale
  • piratetom95 Sep 03, 2008
    so just about a month ago, cd's were working fine. just last week i put a cd in...
    spun for 30 sec. stop started again... stoped... on and on
    the computer never reads it
    i'm running xp on a dell inspiron 1150
  • 121 Answers
Hey Dale,
It sounds like there is an issue with the laser in the CD-ROM drive because it spins for 10 seconds trying to read the disk and stops because it cannot. If you try and put another disk in and it does this then the CD-ROM is bad. You can find replacements online for reasonable prices. You can also go to most electronic stores to purchase a replacement. They usually run around $30 dollars or less.
Thanks - Tech101
Posted on Jun 24, 2008
  • Justin Jun 24, 2008
    Glad to help Dale. If you have any other questions feel free to let me know. Thanks - Tech101
The eject function is not working, the yellow led is blinking, as if the machin was reding a disk, but it never opens. I tried also to open it using the screen option but it does the same thing, the lead...
Take it apart and see if the laser is moving up and down (focusing). If not, then the laser focus servo is bad. After it focuses, the spindle motor should turn and the disc should spin. Remove the spindle lock from the top of the drive case and before it spins quickly place the lock on the disc before it spins to hold the disc in place. If all these processes occur and it still doesn't read, check the lens to see if it's dirty or foggy - clean the lens with "Q" tip and alcohol. if this doesn't work, remove the disk and see if a red beam shines through the lens - if no beam, the laser is bad.
Nov 01, 2010 | LG (GCR8525BK) Internal 52x CD-ROM Drive
Cd drive led light flashes orange four to five times then stops
Given all the things that you ahev done, clean the drive with a CD/DVD cleaner and / or air duster. Check the device is enabled in Device Manager and it shows no errors. If it does then read the explanation. If not and it looks OK you will most likely need a new drive!
Sep 09, 2009 | Computers & Internet
CD-ROM won't spin up
When the CD drive doesn't detect a disc or can't read a optical disc, it stops spinning. Perhaps you need a new CD drive or Lens needs cleaning.
Sep 09, 2009 | Dell Dimension E310 PC Desktop
Dvd drive WILL NOT read burnt dvd's or CD's
The problem occurs mostly when your drive is dying. I had the same problem with my laptop writer recently after which it completely stopped writing discs. Contact your support. Sometimes they would ask you to remove the upper and lower filters of an entry in the registry which would sometimes resolve the problem.
Jun 20, 2009 | Teac DW 28E CD-RW/DVD-ROM Burner
The disc drive wont burn a dvd or even play cd or
was it preinstalled or you installed it yourself ? either way sorry to tell you but drives do give out, and some times the cd-rom and dvd - rom drives the hardest to fix, but you can research and find yourself a new one for around 40-50 dollars...
another thing, if you installed this drive yourself, you can pull it out and check the jumper and make sure its either cable select or slave or master, which ever you want to set it up as....
i usally put all my drives in cable select so the computer will select which drives goes first and things are juts alot easier that way....
Apr 16, 2009 | Acer Computers & Internet
Stiffy drive don't respond and DVD Rom spin but don't read CD.
Try different discs to determine whether it's the disc or the drive. If it's the drive the the lens on drive might be dirty, try cleaning it with proper "Cleaning CD" if that doesn't help the drive it self might be going out (as in the mechanical parts on the drive). In the later case the only solution is buy a new drive.
Jan 20, 2009 | Fujitsu AMILO M-6500 Notebook
Dvd-cd rw drive
This means that your CD-rom drive does not read the CD, it could be that the CD is a different format (DVD, for example) or the lens is dirty or Your drive is faulty. see if your drive is compact or dvd and try the right formats. Try clean your CD-drive lens. If all this does not fix the problem, your drive is faulty. And needs repair.
Oct 31, 2008 | Compaq Presario s4020wm (DK214AR#ABA) PC...
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
Samsung cd-rw drive sh-r522 problem
IF THE DRIVE SHOWS IT ,, then its hardware
eighter the drive is defective or something is wrong with the MB/P
try the drive on a different computer if it works change your mother board format and reinstall
if it didnt work take it back for warrenty or get a new drive
Dec 09, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive Logo
123 people viewed this question
Alun Cox
