Question about NEC USHIO PROJECTOR LAMP, Projector Lamp FOR MT1000/MT810, 250 WTS, 1500 HRS => Model 500081
NEC Multisync MT810 LCD colour alignment
I got this projector off ebay lol and i was told on the auction that there was a slight blur to an image presented on this projector cause of its age. I didn think it was like this, im sure they wernt talking about this kind of problem. They suggested a clean and a service but what do use think will resolve the problem
  • Anonymous Feb 17, 2009
    I think I bought your projector haha
    but seriously I have the exact same problem
  • mikermw12 May 21, 2009
    I have the same problem.
3 Suggested Answers
pctech1
  • 1940 Answers
SOURCE: NEC MultiSync MT810 Projector when turn on , a
If the light is blinking red, it means the projector has a bad lamp or the lamp housing is incorrectly attached.
After you lamp has been operating for 2000 hours or longer, the "status" light in the cabinet will go on. The projector will turn off and go into stand by mode after 2100 hours of service. If this happens, be sure to replace the lamp. If you continue to use the lamp after 2000 hours of use, the lamp bulb may shatter, and pieces of glass may be scattered in the lamp case.
To replace the lamp:
  1. Remove the single screw that secures the lamp housing cover and remove the cover.
  2. Remove the two screws securing the lamp case. (There is an interlock on this case to prevent the risk of electrical shock. Do not attempt to circumvent this interlock.)
  3. Remove the lamp by pulling out the complete assembly.
  4. Install a new lamp case assembly and secure it in place with the two screws.
  5. Reattach the lamp cover and reinstall the single screw.
  6. After you install a new lamp, select the lamp Usage icon and press and hold the "Power On" button on the remote control for ten seconds to reset the lamp time clock to zero. Note: If resetting the lamp clock back to zero after 2100 hours of service, press the "Power Off" (not "Power On") button on the remote control for ten seconds.
Note: When you replace the lamp, it is also wise to replace the filter.
Posted on Jun 06, 2011
m_peel
  • 76 Answers
SOURCE: hi there! i have this
It sounds like a polarising lens has failed, if so it will probably be cheaper to buy a new NEC NP115 which has probably got the same if not better specification.
Hopefully I was of help to you
Posted on Aug 05, 2011
My nec mt810 lcd projector is showing some green colour not sharp colours showing whats problem plz help
It seems that the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 14, 2013 | NEC USHIO PROJECTOR LAMP, Projector Lamp...
I have a nec vt590 projector.When you watch a movie. A big spot appears in the center of the screen. I believe one of the three lcd panels that is attached to the lense has overheated and is distorting...
If it is a bluish colour then the organic polarizer plate that allows the blue light to pass through it to the blue lcd panel is burnt due to old age.
If the spot is made up of pixel shaped spots rather than a blurred area, then perhaps the lcd panel is faulty, but this is less frequently the case.
You could disconnect the power cable and remove the cover and look at the optics parts to check where any overheated parts can be found.
Then you can be certain which bits to replace.
Another option is to buy a faulty VT590 unit off ebay for a fraction of the price and have a go at swapping the parts between the units.
The lcd panels can be removed and replaced, but require precision alignment and you need the extender cables to be able to do it successfully. So give that a miss, replace the whole lcd prism assembly as one item.
Hope this helps.
Apr 10, 2011 | NEC MultiSync VT590 LCD Projector
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
Nec mt 1000
go to menu- go to setting -go to colour move slider to right hand direction befor you change the lamp -take care that some vga cabel(((cabel between pc and projector make this fault).then you have to change this cabel and try.
Mar 09, 2008 | NEC MultiSync MT830 Multimedia Projector
HP-070
Works for a few months?
Is this a new device -?
Check with seller and or makers help site.
Lamps guaranteed for 90 days and Machine for 2 years usually
Jan 15, 2008 | NEC VT465 Multimedia Projector
Double vision-without viewing under the influence
Their are adjustments on the main video board of the projector for alignment of the three LCD screens, But these should only be made by a qualified professional as they can make it worse if done wrong.
Dec 07, 2007 | NEC MultiSync MT830 Multimedia Projector
NEC MT800 Projector with Vertical Lines in picture
The ghosting problem is a combination of both the lcds and driver boards in which case neither need to be truely replaced.. They use a specific voltage to transmit data to the lcds.. Each lcd is different and the driver board is programmed by the factory for the EE v.com setting. Unfortunatly with nec, they do not offer a service mode to go in and adjust the ee settings to correct the electrical convergance. So the only way to fix the problem is to replace the lcd with a newer one who wasnt worn out from long term heat.
Sep 22, 2007 | NEC MultiSync MT830 Multimedia Projector
357 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
