Question about LG Heating & Cooling
Musty smell from wall mounted airconditioner
LGAirconditioner
  • pillis Jun 23, 2008
    The airconditioners are all mounted on an inside wall.Each room has one installed
    Champion:
  • 254 Answers
You need to check to ensure that your unit is sloped to the outside of the window. The correct formula is 1/4" per foot. This can be checked with a level.
Hope this helps Ya please rate me.
Posted on Jun 22, 2008
  • burzerko
    burzerko Jun 24, 2008
    Somewhere there should be a condensate drain maybe this is plugged up allowing water to set in the drainpan. If it is you will need to open up the restriction in the line somehow. Another option may be to buy algea tabs from an hvac supply store. You can place one of these in the condensate pan around every 3 months in the summer time.
SMELL FROM HEATER IN XF JAG
What kind of smell? Sweet like coolant or a musty, decomposing like smell? If sweet like antifreeze it could be your heater core if musty/mildewy or decomposing like smell try replacing your cabin air filter.
Apr 18, 2014 | 2013 Jaguar XF
Horrible musty smell
try to find the filter or look it up on the internet.
Dec 17, 2013 | MSZ-A17NA 16,200 BTU, Mr. Slim Wall...
Hi I have just moved into a new house and there is a musty smell coming from the electric Dimplex heaters fixed to the walls. is there any way of getting rid of this smell? thanks# Mary
Are the heaters hydronic? (Heated water flowing thru tubes) If so, the musty smell is because the water has been leaking which is obviously a problem. I know you mentioned that they are electric heaters, but "musty smell" goes hand in hand with moisture.
Aug 03, 2011 | Heating & Cooling
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
2008 NEW BEETLE MUSTY SMELL FROM AC, WHERE DOES THE AC DRAIN GO THROUGH THE FIRE WALL
The drain should go through on the passenger side under the dash....you might need to replace your cabin air filter.
Aug 26, 2009 | 2008 Volkswagen Beetle
Interior Smell, musty mold smell
run water over the winshield ..keep eye on the fire wall and sides. also check the florr if is wet. water is likin somewere
Feb 25, 2009 | 2006 Chevrolet Equinox
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell
Make sure the door is kept open when not in use and also make shure that you do the cleaning procedure as described on the book once a month.
May 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Heating & Cooling Logo
710 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
