hi didnt use mine too for 1..but still works after keeping plug to the charger before i sleep, at first it has no light which is supposed to have red light while charging but when i woke up after at least 8 hours it showed blue light..:)
Your headset is compatible with any device that is bluetooth enabled. The easiest way to check is your phone manual or the device menu or settings screen of your phone. So if you know the phone supports bluetooth, it is just a matter of enabling it. Hope this helps. Have a great day.
You will have ro place the headset in discovery mode this is usually done by holding the button down for about 5 to 8 seconds you will see the Bluetooth indicator turn solid blue or flash quickly.
Then you will need to go to the bluetooth setup on you phone once it discovers the device it will ask you for the pairing code which is usually 0000. Once it is done you should be on your way.
Same here, except i cant seem to be able to pair the wep250. I Used it first with my phone and it worked, then i deleted it and disabled it off of my phone, now i cant seem to pair it with my ps3. :( Do u have any suggestions?
on msot samsungs you would go to settings then security then PIn check then disable. It will ask you for your PIN code after you enter it the code will be off.
If you have forgotton your PIN code....
If the wrong PIN code is entered too many times your phone should ask for a PUK code. Your carrier can provide this code for you andit will allow you to reset the PIN on the phone
