Question about HP LaserJet 2550Ln Printer
Help There's a light flashing against a symbol of a spanner, what does this mean?
  • 42 Answers
This means your drum cartridge is close to expiring and will need replaced.
Open front cover lift out cartridge by the big green handle install new one after removing all packing materials-see instructions included with new drum/transfer kit.
Posted on Jul 30, 2008
Spanner symbol has appeared on dashboard display .
service due or fault code that needs attention
run the fault codes to determine if there is a problem
Sep 09, 2017 | Cars & Trucks
2011 terios . Yellow spanner light comes on. What does that mean
The yellow spanner light indicates a service is due
Jul 09, 2015 | 2010 Daihatsu Terios 1.5
Dash symbol car with spanner through
Your car only has one bank, so this code applies for the entire engine. I'll provide a link that gives a good breakdown of what P0170 means, possible causes, and possible corrections.
P0170 Fuel Trim Malfunction Bank 1
Aug 01, 2017 | Cars & Trucks
I have a spanner symbol on my 407. what does this mean??
You need to carry out the periodical car service due (e.g. engine oil & filter, air filter, fuel filter, cabin air filter). The "service" spanner symbol "reset" button is placed on the lower right corner of the dashboard. See picture below:
Then you should reset the "service" spanner symbol by pressing on the "reset" button on dashboard, when ignition key is in OFF position. Hold the button pressed and turn ignition key in ON position. Hold the button pressed and see on the dashboard successive numbers will appear: "10", "9", "8", ... , "1", "0". Then release the button and switch OFF the ignition key. The "service" spanner symbol followed by "20000 km" (or "30000 km" depending of the engine type), will appear for few seconds after turning ignition key in ON position, and will dissapear after engine starting. The car service due was reseted.
Please do rate my response. Thanks!
Feb 21, 2011 | 2005 Peugeot 405
Hi....f 13 is flashing on the machine and a red spanner symbol is on all the time, also unable to open machine even after draining it manually... thanks for any help you can offer.
You did not say what machine you have!
F 13 I have is a dispenser circuit error and the causes/procedures are
1 Unplug the washer or disconnect power
2 Check the mechanical linkage from the motor to the top of the dispenser
3 Check the wire harness to the dispenser motor and the central control unit
4 Check the dispenser motor for powered rotations
Replace faulty components
If there is a spanner symbol lit it means you need to call a repairman.
Feb 17, 2011 | Washing Machines
How do i reset the service spanner symbol on my aprilia 125 leonardo sport city scooter
Ok, disconnecting the battery does NOT reset the service light. To reset the service light (spanner symbol) on dashboard you must hold the mode button for about 5 seconds with ignition OFF then while still holding the mode button turn ignition on, continue holding the mode button for a futher 10 - 12 secs and then it should just disapear. This solution was brought to by RPMs. Mobile motorcycle service.
Oct 30, 2010 | 2007 Aprilia Sportcity 250
It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
Apr 01, 2010 | Whirlpool Washing Machines
Spanner flashing on dash renault megane 2003 1500 dci
the spanner symbol is indicating your engine/car is due for service/maintainance which if your vehicle is high milage ?/ it may also require the cambelt renewal and the tensioner may i suggest you do not ignor this warning light i am sure you have heard horror stories of the consequences of engines cambelt breaking ?? hope this helps and you heed advice given ?
Mar 09, 2010 | 2004 Renault 181
HP LaserJet 2550Ln Printer Logo
108 people viewed this question
Seeker5211
Seeker5211
