Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Drip tray does not move up or down
My new saeco primea touch plus machine does not move the drip tray up or down. This happened from new Is there anything I can look at ? I brought the machine back from europe to south africa and there is no support for them here !!
Thanks Roger
  • 796 Answers
Click here to download the manual
Posted on Jun 20, 2008
I have a Saeco Pimea Cappuccino touch plus cofee maker and it says in the screen to empty the drip tray under the brewer goup. I have done several times, washed the dtray, fdried it and put it back in the...
Hi Darrell,...Make sure the part of the machine where the driptray fits is all dry.(no wet ground coffee stick on the wall) Itis possible the water sensor inside the machine is sensing wetness behind the drip tray. Hope it helps.
Aug 15, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
I have a Saeco Talea. The drip tray will go up
Probably the touch pad is faulty. Before we decide that make sure the bottom touch area is dry and nothing sticking on to it.Can be check by removing the 2 screws underneath.
The worst case senerio will be the CPU which is not receiving the signal from the touch pad.
Jan 10, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Empty drip tray warning stays on despite tray being empty
Subscribe to my Premium Plan and I will tell you how I fixed it
Oct 30, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Error 1 on saeco primea touch plus
The grinder motor is not working,,better to take it to the service center to replace a new one under warranty if the machine is new.
Oct 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Water not running through the machine!
sounds like air got in the water lines. Try turning off the machine and making sure the tank is seated good. at menu try an get hot water to get the pump flowing again. you may hear a loud "eh-eh-eh" buzz which means air is in the pump. It will quiet down as the air is forced out. try it several times. Hopefully you get it working. Just remember not to run the tank completely dry.
Apr 03, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Insert Drip Tray
Check the right side of the tray holder. There should be a small lever (micro-switch) that you can feel and press in. If it does not click when pressed then you need to replace it at a service center. If the leaver just broke off (a small triangle piece with a tab on the end) then you may be able to stick a piece of card board to make the switch click and fool the machine to think the tray is in. until you can get it to a service center. ukeboy@pixi.com
Dec 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Flow
Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased.
If not, Contact saeco usa for support at 800-933-7876.
Out of warranty repairs can be completed by Cerini Coffee located in New York.
www.CeriniCoffee.com
Replacement parts for your saeco espresso machine located at http://cerinicoffee.com/Saeco_replacement_parts.asp.
Nov 23, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
The touch lift drip tray is broken its the plastic shaft that holds it together so its unusable.. I think someone lifted the machine by the lift tray or the shipper put the box upside down and it broke.......
The entire machine need to be taken apart to repair the auto drip tray. I would reccommend a Authorized Service Center to replace the tray. It is again not a simple fix.
Saeco's First Authorized Service Center of New York
Cerini Coffee Service
718-584-6120
Oct 08, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
108 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
