Question about Zenith R40W46 40" Rear Projection HDTV-Ready Television
My tv has very similar problem,arced red lines and ghost lines.
How do i check my resistors? where can i buy the parts i need? oh and where is the board located in my tv r56w36 zenith crt projection
  • Charles Stillwell
    Charles Stillwell Jun 20, 2008
    I FOUND THE BOARD.BUT CANT FIGURE OUT WHERE TO BUY ONE?
  • Charles Stillwell
    THE PART# IS 346871VSMA97E011
  • Zenith Master
  • 8,617 Answers
Go to this link and leave them a email state your model number and what youre looking for they will respond quickly.
http://servicemanuals.vstore.ca/
Posted on Jun 20, 2008
Red color shifting and ghosting on my wt-42315
Tv have a problems known as a convergence picture problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board have dead parts like 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must have be replaced to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jul 07, 2011 | Mitsubishi WT-42315 42" TV
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
My TV looks like it had permanent 3-D. Red Ghost
hello it sound like the convergance ic may be the problem these chips sit behind the tuner board connected to a metal frame called a heat sink they are soldered in. also you will have to check the resistor in front of the chips also check the 2 capacitors at either end it would be best to get a quote from and engineer good luck
regards
shaun
Jul 10, 2010 | Sony KP-51WS510 51" Rear Projection...
Ghost image arcs over picture
This tv have a convergence problems,it dead.The covergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be replaced to solved covergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Philips Magnavox 51MP392H Rear Projection...
Red arched ghost
But be careful as TV has high voltage inside.
Jul 16, 2008 | Hitachi 57F500 57" Rear Projection...
Convergence board
YOU WILL NEED PROFESSIONAL HELP THIS IS NOT A DO-IT-YOURSELF JOB. SORRY
Jun 01, 2008 | Mitsubishi WT-42315 42" TV
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Lightning Strike, Plz Help!
Hi. The red line on ICS is quite normal it does not mean the part has failed. To be honest in most cases if a tv has been hit by strike it is a right off & scapped. What I suggest is to remove the main pcb & power supply pcb if its seperate & inspect the print side of pcb for signs of arcing tracking or burnt track. Repair any damaged track by cleaning off the coating to get at clean copper then solder wire accros to bridge the damage. Check the power supply resistors diodes transistors look carefully for any burnt components or components which are physicaly damaged. Check the line output transistor this will be near the large transformer with a thick red ht lead going up to the crt. Check all the components you can in the line stage look at all the ICS to ensure none of them have holes in them or have blown apart. Hopefully you find some or one if your very lucky that is damaged replace it & try your tv.
Sep 23, 2007 | Toshiba CZ36V61 TV
Sony KP-57WS500 Pictures problem
Your Convergence Correction Amplifier ICs have gone bad (STK329-110) They must be replaced along with the biasing resistors
www.electronix.com has the parts you will need plus I would suggest that you have a qualified TV repair person do the installation for you.
Make sure the traces on the circuitboard are good and that the solder connections are good.
But the ICs and resistors need to be replaced.
Thank you,
Shuttle83
Oct 30, 2006 | Sony KP-46WT500 46" Rear Projection...
Zenith R40W46 40" Rear Projection HDTV-Ready Television Logo
153 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
