Question about Kitchen Ranges
Electric range element won't adjust in temperature
One of the four elements on my electric range is suddenly malfunctioning; it stays on high. I hadn't used the stove for the better part of a day, but it had been working up until then and there have been no changes I can identify. This evening I set it to medium and then to low and found it heated up to high. The problem persists. The only possible diagnosis I have found online is that the "switch control" needs to be replaced. Does that sound right? Is that easy and inexpensive to do?
  • 1 more comment
  • A789 Jun 20, 2008
    Thank you for your response and encouragement.
    Can you be more specific in describing what to check? I am not familiar with the parts.
  • A789 Jun 20, 2008
    I do not have a meter. I do not know which part might be the temperature sensor. I am somewhat competent to fix such things, but I need to have a description of what part is what. All I see is the place in which the element plugs an dthe wires. I don't know what you mean by hob or where to find the temperature sensors, and I don't know anything about changing a control switch, starting with where to find it.. Please describe.
  • A789 Jun 20, 2008
    Make is Sunray.
    How much do these parts generally cost?
Thanks for the pointer to the search page for parts. That is somewhat helpful, but I don't see the oven overview to help put it all together.
Oddly enough, after my last comment, it began working again! Perhaps I wiggled something I hadn't previously wiggled?
I wonder whether this was a short-lived, one-time problem or will be intermittent.
Posted on Jun 20, 2008
  • 1,036 Answers
Yes you're right.
Inexpencive to do yourself and fairly easy if you are used to maintenance.
Check the item first for any loose wires, or anything obvious. No point in ordering a replacement if it's a quick fix.
If your hob has any temperature sensors fitted, it could be a faulty sensor - which the switch control then overcompensates for.
This is typical in radiant heaters, as they come on full untill the temperature is reached.
  • Richard Perkins
    Richard Perkins Jun 20, 2008
    The best method is a comparative check. With a test meter set to Ohms, check the resistance of all 4 sensors (I still don't know much about your model) - and find the odd one out.
    Likewise there should be a major difference in the outputs from the controller when set to full or low.
    If you are not competent to repair, I would advise a technician do this. Make sure the appliance is disconnected before checking anything.
    If you list the make and model, and nearest town, I can find spares in your area.
  • Richard Perkins
    Hi again,
    Click Here to find a general overview of the oven, and a prts list with pictures.
    Let me know if you find what you're after.
    Digital test meters are very cheap thesedays and will come in very useful for you. I advise you get one, along with a Safety mains tester. This will warn you if the equipment is still live.
Hello Miguel;
My name is Peter. I am a retired field service appliance technician.
There are two electrical components that will cause this problem. The most probable cause is the burner element. Each of your burner elements have a independent temperature sensor. The sensor controls the burner element temperature.
Substitution Part Number: 4453909 Cost: $85.00
This surface element (part number 4453909) is for electric ranges, including Whirlpool electric range model GJC3034RB00.
Unplug the range or shut off the house circuit breakers to disconnect electrical power to the range before replacing the surface element. Wear gloves to protect your hands when replacing surface element on your electric range.
This is a manufacturer substitution. Part may differ in appearance but is a functional equivalent to priorparts including 9759351.
PART NUMBER: 8523698 Cost: $71.00
The other less likely electrical component is Surface Element Control Switch. Each burner has a independent control switch.
Cost: $46.00
To check the switch: Remove the switch 2 contacts on the left. With a multi-meter, set the meter to the lowest Ohms (Omega Symbol). Put one meter lead on one switch contact and the other meter lead on the other contact. If the switch is good you meter will read "0" Ohms.
Jan 18, 2015 | Whirlpool GR673LXSS - Stainless Steel...
The "element on' light on my Kenmore Electric Range wont turn off.
The element on indicator is typically controlled by the infinite switch (the temperature control) for the element.
Jan 01, 2014 | Kenmore 96412 / 96414 / 96419 Electric...
Maytag Oven won't work
either you element is bad or the relay on your control will not open , if able check voltage to element and inspect element for defect .
Feb 20, 2013 | Maytag Kitchen Ranges
Burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as
Apr 26, 2009 | Frigidaire FEB27T5D Electric Double Oven
Ceramic top temperature control
This would be a faulty switch. Hope this helps!
Mar 08, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchen Ranges Logo
145 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
