Question about RCA P56930BL 56" Rear Projection Television
RCA P56930BL 56 in. Rear Projection Television
Can you send the the link for that part? Thanks for your help.
  • RCA Master
  • 8,617 Answers
Heres the link, if you dont see your part listed leave them a email with your model number and what youre needing and they respond quickly.
http://servicemanuals.vstore.ca/
Posted on Jun 20, 2008
I need a new screen protector for my older RCA big screen TV
I have a screen protector from a 1998 RCA older model big box style tv
Mar 15, 2010 | RCA P56930BL 56" Rear Projection...
Tv beeps
That is means one of the capacitors inside the TV is bad. You can get the capacitor replaced, but it normally takes an expensive technician. We had the exact same problem with one of our tvs and the repair was 230$. If the tv is still under warranty have the manufacturer fix it. If not hire a tv repair technician. I do not reccomend fixing it yourself because it can be dangerous even fatal.
Jun 15, 2009 | RCA P56930BL 56" Rear Projection...
My tv screen is out of focus
THAT IS REPEATED PROBLEM WITH THE RCA AND PHILLIPHS PROJECTION !! THE DEF;ECTION BOARD WHICH IS THE ONE WITH THE TRANSFORMER HAS LOOSE CONNECTIONS AROUND IT AND THE FUSE BLOWS .RIGHT BESIDE OF THE TRANSFORMER ,THEY ARE LITTLE RED SQUARE COMPONENTS !! THE ONE IN THE MIDDLE OF THE 3 IS BLOWED ,I THINK ITS A 1.25 AMP ,JUST REPLACE IT AND RESOLDER THE CONNECTIONS AROUND THE XFMR AND U SHOULD BE SET TO GO !! I HAVE OVER 40 YRS OF TV REPAIR AND AM STILL DOING IT !! IF U HAVE ANY QUESTIONS E-MAIL ME !!
Jan 23, 2009 | RCA P56930BL 56" Rear Projection...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
P56930BL focus problem
Sounds like you need a new focus block, they are actually cheap. If you need a link on where to get one let me know.
Jun 20, 2008 | RCA P56930BL 56" Rear Projection...
D52W26
call RCA and give them a M# thay you send you the not cheap.
or go to part store.comor rca part.com
Mar 30, 2008 | RCA P56812BL 56" Rear Projection...
56" RCA projection, model P56930BL, no power up.
#1 problem in this model for not powering up is the color wheel needs to be replaced or it could be the lamp is burn out or it could be the ballast it bad. But the #1 problem is the color wheel.
Mar 28, 2008 | RCA P56930BL 56" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
RCA P56930BL 56 in. Television
Used prices for that unit now would be around 400.00 in good condition
Oct 23, 2007 | RCA P56930BL 56" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
