Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Two beeps Whan I turn it on I get two short beeps. And there is no display on monitor.Need to know the beep codes a solution for that.
I know that three beeps continued adfinightum
is a sign of loose memory
Posted on Jun 29, 2008
    Problem Solver:
  • 16 Answers
1) You need to change your memory, the may be bad, and it will not display anything on your screen.
2) Make sure that your processor fan is well connected
Jowinson
Posted on Jun 20, 2008
Any help for beeping acer laptop when opening..thanks
g'day!
i would like to know how many and the kinds of beeps? there are what they call beep codes which indicates what kind of problem the your laptop is experiencing: here are the common ones:
0 beep = no power, loose card, short
1 short beep = normal,POST (Power On Self Test), your computer is ok
2 short beeps = POST error, review screen for error code.
continuous beeps = no power, loose card, short
repeating short beeps = no power, loose card, short
1 long, 1 short beeps = motherboard issue
1 long, 2 short beeps = video issue
1 long, 3 short beeps = video display circuitry
three long beeps = keyboard/keyboard card error
one beep, blank, incorrect display = video display circuitry
aside from the 1 short beeps, you need to take your laptop to a technician to have it looked at.
cheers mate!
jelo a.
Aug 21, 2011 | Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
PC power on but doesn't display anything on the monitor and has a beep code of different intervals of time. Here are the beep codes: 2 beeps, after 1 sec, 8beeps, after how many seconds 2 beeps after how...
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to: http://www.computerhope.com/beep.htm#04
Jan 09, 2011 | EliteGroup P4VXASD2 Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
Black screen with error codes
I think the msg you are seeing is just the default monitor message when there is no video to display. Here is a list of common beep codes: Are you getting the one long beep at each restart?
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 16, 2008 | Computers & Internet
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
thnk you.
Nov 29, 2008 | Computers & Internet
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Computer will not boot
3 beeps = memory
long beeps = processor
long and short mixed = main board,,,
yours sound like memory, try the memory in another pc and see if it works
if it does its your processor
cheers
Jan 05, 2008 | AOpen AX34-U Motherboard
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
97 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
