Question about Pioneer PD-F805 CD Player
Cd's are stuck inside
I was loading 3 cd's into the player. everything was going great, until the 3rd cd.
it was taking it as i was turning away.i turned to look at it as it was trying to eject it.by the time i got back to the player it pulled it back inside. what shall i do.
kathy
    Genius:
  • 1,036 Answers
Hi there!
It may have misloaded the first attempt, so ejected. Doing this may have settled it on the centre, and corrected the problem.
Try ejecting everything in there. If you hear a motor straining or other malfunction, disconnect, then start up after 2 minutes again. Eject it the first opportunity you have.
Posted on Jun 20, 2008
The cd player in my car is A56820, JBL, it will load and eject cf's but not read. any fixes?
Did you get all of the CDs out of the player or are any still
stuck inside the stereo? Its the part about everything working
OK until a disc changed that makes me ask.
If a disc is jammed because it didn't load properly, you won't
be able to get all your discs out.
Oct 23, 2014 | Audio Players & Recorders
2000 Volvo S80 service transmission urgent just came up. Never had any trans problems before, and this didnt go off until I hit a huge pot hole in the road(so hard it caused my cd player(stock player) to...
I think there is a possiblity that the ABS Braking System
had a role there
Hopefully that was just a normal car issue,although one
that won't be understood, if all continues as in the past
Dec 16, 2012 | Cars & Trucks
I have a 2008 ford fusion. i just loaded a cd into in dash cd player and it now comes up with a "load error". i tried to eject it as well and it tells me "eject error'. it took my cd but it...
See if the cd is not fully inserted, take another cd and gently try to put it into the cd player to push any stuck cds back in. If this does not work you will need to replace the radio.
Feb 28, 2011 | Car Audio & Video
I bought a RCA 5 DVD Disk Changer last Christmas.
my suggestion (not necessarily solution) is cleaning.
Although it can take multiple DVD's there is only one reader inside of it.
Do you have small children?? :-)
May 13, 2010 | RCA RP8065 5-Disc CD Changer
2006 ford explorer cd player says load error how to fix
remove the cd player and most likely replace - but try taking it out and finding the reset button - - hit reset and there u go - sometimes it works - also check and make sure no one stuck something smaller than a cd in the hole --
Dec 26, 2009 | 2006 Ford Explorer
CD STUCK IN CD PLAYER
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
Sep 07, 2009 | 2007 Chevrolet Avalanche LTZ
DUAL XDVD9101 PARKING BRAKE BYPASS
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
FACTORY RESET METHOD (not permanent)
1 Go to the Menu
2 Get to the Settings Menu
3 Select <yes> to Reset to Factory Settings.
Have recently heard complaints of this method not being permanent, as this is needed whenever they want to watch a DVD. Also, radio and screen angle presets are lost.
METHOD 2
AUDIO CD METHOD (Permanent)
1 Insert Audio CD
2 Press PLAY
3 Press STOP twice on remote
4 Enter 26604 on remote
5 Press ENTER
6 Take out Audio CD and Insert a DVD
METHOD 3
DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
The 3rd method seems to work with most of the duals
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 18, 2009 | XO Vision XOD1742BT Car DVD Player
2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
Apr 17, 2009 | 2002 GMC Envoy
Changing a brake light
Rear: Brake, Back-up, Tail, Turn signal (3 bulbs, all # 3157) To access the rear bulbs, open the liftgate and remove the two phillips head screws from the side of the housing. There is no 3rd screw. There is a metal rod with a ball tip which is stuck in a rubber socket on the vehicle. Slowly and firmly rotate the assembly away from the vehicle until it disengages from the ball pin socket that secures it in back. Rotating it away from the vehicle give you leverage to smoothly disengage the ball from the socket. Each of the three light sockets, all containing the same exact bulb type, can be removed by turning them counter-clockwise 1/4 turn.
Mar 04, 2009 | 2004 Jeep Grand Cherokee
Curtis DVD player - Stuck in Load Mode so won't open - dvd inside - correctly seated - but may not be compatible. I just burned it & was testing it.) Have tried the paper clip in the tray release...
Do the following
Unplug power cord.
Wait two minutes and plug it back.
Keep repeatedly pressing the eject button while you start the unit, before it starts reading cd inside. Do this a couple of times.
If you cannot eject the disk in this way you will need to take unit apart.
Unit won't start until the disk is inside, as it tries to read the disk , disk is faulty and unit get stuck.
Aug 26, 2008 | Televison & Video
Pioneer PD-F805 CD Player Logo
131 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
