Hi, can you help me please. I have a dell c640 laptop. It switches on for 5secs then goes off. I have found a m5236 -3.3BM chip over heating (very hot). I have ordered a new one. but there must be something that causes it to over heat with too much power going to it. DO you know if it's a faulty transistor or something? thanks
  • spike47 Mar 13, 2009
    Hi there rupertbear
    I have the same problem , but I cant identify the transistor on U45 , it has S60 on it but I cant find anything relating to that number ! , could you give any more info on it ! .
    cheers
Hi.
The part you are looking for is a reset signal ic with a treshold of 2.93v. There are many parts available that work the same. Like the MAX809s, the STD809s and the MAX6326_UR29. BTW the part description says "09S" not ""S60"
Mark
Posted on Mar 28, 2009
Hi
problem is transistor u45 gone short circuit.This is 70mm due north of the micrel Mic5236-3.3bm.Forget the fan.
Rupert
Posted on Jul 04, 2008
If it is the processor that is overheating , usually the computer has a "fail safe" when it overheats. It would does an auto shut down so your motherboard does not fry. I would recommend checking to see if your CPU fan is working.
Posted on Jun 21, 2008
Dell latitud c640 wirelessnetwork adapter where does it goes ?
combination of switch to turn on or of wireless adapter on laptop see manual
press switch on your laptop to turn on of wireless
install driver
check in bios for turn on of card
have fun
Aug 07, 2012 | Dell Latitude C640 Notebook
Where is the on/off wirless switch on a dell latitude c640 laptop
try to press CTRL+F2. there's no wireless switch at your dell latitude c640.
Apr 02, 2010 | Dell LATITUDE C640, P4...
Hi, the latitude c640 starts to boot and cuts out - no way of getting into bios, doesn't even start showing the bios before it dies, any help? andy
This could be a heat problem if the processor heatsink has become unseated or filled up with dust/hair/ etc.
remove the 6 screws labeled "k" from the bottom, remove the keyboard and inspect/clean it.
Oct 28, 2009 | Dell Latitude C640 Notebook
I got a dell 640 but it does not turn on, it starts to turn the lights on...but it doesn't turn on the monitor
The first and easiest thing to check first is the memory. I have seen alot of Dells that the memory burns out and will not let it come on. Try Pulling the memory and replace 1 chip at a time and try it. Good luck and have a great day.
Oct 26, 2009 | Dell Latitude C640 Notebook
Hi iv got a dell c640 when i swith it on the power goes off before it boots up I nearly got to safe mode once but power went again. The battery is ok but after it turns it self off its showing no signs of...
sounds like a motherboard port. remove the battery and try to power it on again with the AC adapter. If same issue, try another AC adapter, try removing the hard disk and DVD drive if available, and test it again.. If no luck, request for a motherboard replacement if within warranty, otherwise, you will have to contact their sales support to purchase a replacement board
Oct 23, 2009 | Dell Latitude C640 Notebook
Audio driver dell latitude C640 not working on my laptop
http://supportapj.dell.com/support/downloads/driverslist.aspx?c=in&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_P4N_C640&os=WW1&osl=en&catid=&impid=
download drivers from here
Nov 08, 2008 | Dell Latitude C640 Notebook
Vga card driver
It has a ATI Mobility Radeon 7500 graphics chips and u can dl the drivers from: http://ati.amd.com/support/driver.html
Oct 14, 2008 | Dell (1R493) (32 MB) Graphic Card
Dell latitude c640 laptop
This could be caused by a number of thing, bad battery, bad power supply, bad memory chip, bad processor, and a bad component on the motherboard. Start by checking the output of the power supply with an ohm meter. The output rating will be on the power supply or you can go by the input in the machine. Then try starting without the battery. Then remove the memory and try with one chip then the other. At this point, if the problem persists, you will need to take it for a professional diagnosis. They will be able to test the processor and motherboard to find the exact problem component, and tell you whether it's replaceable.
Jul 23, 2008 | Dell Latitude C640 Notebook
Latitude C640 is dead!!
I have the exact same issue. It's not the processor. If you have you power supply tested, you will probably find that it's not working anymore. The green light still comes on when plugged in, but it's not sending the "charge" to the notebook.
I have this issue with a couple of C640's. I've tested the machine by charging the battery in another (Pentium 3 Dell C600), then putting it back into the broken machine... woohoo it works.
Unfortunately I can't figure out why the power supply's keep on busting, I don't think that the power-supplies are faulty, or maybe they just get old, don't know, but the most obvious problem is probably something with the mainboard, which really sux.
Hope this helps,
Oct 09, 2007 | Dell Latitude C640 Notebook
Dell latitude password bios forgotten
Hi, The only way for that is to contact dell support. you're gonna need help from a level 2 tech from austin as they're the only one who has the master password for that.
Oct 03, 2007 | Dell Latitude C640 Notebook
Computers & Internet Logo
281 people viewed this question
David Payne
David Payne
